DAG for site resillience
JohnBravo
Hi Guys,
I am looking at implementing a DAG across two physical sites to offer site resillience with two MB servers in one site and one (or two) in the other. My problem is I am not sure what would happen if the site to site link was to become unavilable and the servers in one site couldnt contact the witness server?
Are there any options that would allow me to specifiy another parameter to check so that the mailbox copies do not failover to the other site and become available for the users at one site? Ie can I tell the DAG to check if it can ping the other server, for example in the site before the DAG brings the databases up at the other site.
Any pointers on this would be very well received.
John
L
lAdK
DAG does not support link failures so any site failure will yield the site with the smaller number of nodes to lose quorum
the best you can do is to disable automatic failover but this will not change anything to the fact that the servers will lose quorum and will be dismounted they just won't go online in the other site
Full time IT consultant since 1998 mainly on Exchange\ISA\AD MCSE NT4.0,2000/2003, CCNA MCITP: Enterprise Messaging Administrator 2007/2010 MCT since 2001
C
Catastrophic Failure
Hi JohnBravo,
You can use high availability and site resilience to design, build, and operate a highly available messaging solution based on Microsoft Exchange Server 2010. You can design and deploy a configuration that enables site resilience, and use procedures related to the various backup, restore, and recovery operations supported by Exchange 2010.
Use the following links to access the information you need about high availability, disaster recovery, and site resilience.
For more information take a look here:
ü High Availability and Site Resilience
ü Managing High Availability and Site Resilience
ü Planning for High Availability and Site Resilience
Regards
Catastrophic Failure “JV”
Catastrophic failure is a sudden and total failure of some system from which recovery is impossible...Thats me....!
J DAG for site resillience Exchange Server Administration 3
S DAG Deployment Design with site resiliance Exchange Server Administration 2
S single DAG two AD sites cross site database failure Exchange Server Administration 3
B dual site DAG configuration Exchange Server Administration 2
D DAG for site resiliency Exchange Server Administration 4
S Stretching an AD site and DAG's Exchange Server Administration 5
S DAG Membership/DR SIte Exchange Server Administration 1
K Cross site DAG and CAS Exchange Server Administration 7
S Can a DAG Cross Site Bounderies Exchange Server Administration 1
S Create DAG for DR or site resiliency Exchange Server Administration 4
S DAG question Exchange Server Administration 0
B Two server DAG setup, second server EMC not opening Exchange Server Administration 3
L DAG Requirements Exchange Server Administration 5
G Mount recovery database fails on DAG Exchange Server Administration 3
S Mailbox Stores not mount in Two Member DAG Exchange Server Administration 4
P DAG CONFIGURED Need to change the data base and log file location .What are the risk .And Steps to p Exchange Server Administration 3
A Exchange DAG Exchange Server Administration 1
V mapiexceptioncallfailed: unable to mount database when activate mailboxdatabase in dag Exchange Server Administration 4
S DAG Content Index failed Exchange Server Administration 2
E Outlook 2007 won't connect to 2nd Mailbox Server in a DAG Exchange Server Administration 2
S DAG with Single Network Card Exchange Server Administration 8
T Exchange 2010 DAG Failover Issue - Database Activation Fails because Content Index Catalog Failed Exchange Server Administration 2
L DAG Question - Help Exchange Server Administration 2
A Access a DAG over a virtual lan ip for backup Exchange Server Administration 1
J Question of Exchange 2010 DAG Exchange Server Administration 3
M Hyper-v vSwitches and DAG Networks Exchange Server Administration 7
A Need Help Urgent !!!- Add Seconde Node To The DAG Exchange Server Administration 12
P 2 Member DAG - Members Virtualised running on non Clustered Hosts - supported Configuration? Exchange Server Administration 2
P Two Member DAG - Reboot Witness Server - Effects? Exchange Server Administration 7
K Exchange 2010 DAG Exchange Server Administration 2
S DAG replicaiton and server maintenance Exchange Server Administration 6
J When a database move from active host in a DAG, user are prompted for credentials Exchange Server Administration 8
à Loss the file share witness of DAG Exchange Server Administration 4
S DAG RPCclientAccessServer Exchange Server Administration 5
K msexchangerepl utilizing high CPU in a DAG env Exchange Server Administration 10
S Extend Exchange 2010 DAG accross sites Exchange Server Administration 3
M DAG layout and space question Exchange Server Administration 2
S DAG manually dismount database Exchange Server Administration 4
M Exchange 2010 DAG Witness Server Help Exchange Server Administration 2
H Shutdown all member in a DAG Exchange Server Administration 2
J DAG problem - I´m not able to recover database Exchange Server Administration 9
S Active Passive DAG seperate DNS namespace Exchange Server Administration 7
T DAG Exchange Server Administration 3
D DAG Failover Treshold Exchange Server Administration 5
J Roll Back Options for installing SP1 on a DAG Exchange Server Administration 5
P Failing whn adding a server to a DAG Exchange Server Administration 5
S Change IP on DAG and DAG Members Exchange Server Administration 2
DAG
