Mail merge to create labels for Outlook contacts DOES NOT WORK
dale.sheets
Outlook 2010 with Word 2010. I select the Contacts to create mailing labels and get to the three steps: Setup, Data Source and Get Data. The Merge button in Step 3 is " greyed" out. Nothing I do will let the labels be displayed and printed with the correct data from the selected Contacts
Ben M. Schorr [MVP]
Did you Setup a merge document that includes the fields you want to merge?
Did you select the Data Source?
As Ben suggests, you need to hit Setup first. When you start the merge from Outlook, the Merge button may always be disabled - you'll go into the document and add the merge fields, then finish the merge from Word. Seehttp://www.slipstick.com/tutorials/merge/merge.asp for a tutorial. It was created using an older version but its pretty much the same in Outlook 2010.
K Delay Send and Mail Merge Outlook VBA and Custom Forms 4
M Mail merge to single contacts + contact groups? Using Outlook 4
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge New Slipstick.com Articles 0
iwshim outlook mail merge -rich text Using Outlook 2
Diane Poremsky Add attachments and set email fields during a mail merge to email New Slipstick.com Articles 0
H Mail Merge status remaining "Not Executed" BCM (Business Contact Manager) 1
iwshim mail merge and add the contact picture outlook 2013 Using Outlook 3
A Reply/Forward Emails using Mail Merge BCM (Business Contact Manager) 0
S Custom field not populating in Custom View or Mail Merge Exchange Server Administration 2
W Combine Mail Merge to Distribution List with Auto Attachments - Outlook 2007 Using Outlook 1
M Using mail merge with stationery Using Outlook 5
P Mail Merge vs Direct Mail Print BCM (Business Contact Manager) 4
A Mail Merge - Sent but still in Outbox Using Outlook 5
R specify from account in mail merge Using Outlook 3
G Mail Merge via Proxy Email? Using Outlook 2
A Outlook 2007 Mail Merge not working anymore Using Outlook 1
J Contacts Notes field will not mail merge after migration to Exchange 2010 Exchange Server Administration 1
D Publisher 2010 (x64) not connecting with Outlook 2010 (x64) via Mail Merge Using Outlook 1
J Mail merge, labels, contact lists, address block Using Outlook 2
F Office 2010 Mail merge into Work 2010 using a specific Outlook catagory filter. Using Outlook 2
F Attachments (such as pdf) in a mail merge Outlook 2010 Using Outlook 1
F Mail merge in Word/Outlook 2010 using multiple email accounts in Outlook Using Outlook 2
J mass email limitations when sending mails using mail merge. Using Outlook 2
S Merge Outlook mails to Windows Live Mail Inbox Using Outlook 4
H Mail Merge Contacts Using Outlook 4
T User-defined fields in Outlook to be incorporated into Mail Merge documents Using Outlook 1
I E-mail Merge with Word/Outlook 2010 Exceptionally Slow Using Outlook 3
C Issues with ctearing mail merge file with Outlook 2010 & Win 7 Using Outlook 1
M Mail Merge email using data from MS Access Using Outlook 1
A Using Mailing Address in Mail Merge with BCM Using Outlook 1
V Outlook 2010 - attachments with mail merge email Using Outlook 4
1 MAIL MERGE NOT WORKING Using Outlook 5
G Problems Sending Publisher Mail Merge Newsletters Through Outlook. Using Outlook 1
B Subject heading with mail merge Using Outlook 2
L mail merge trouble 2003 - sends only 2 out of 150+ entries in data file Using Outlook 1
C Mail Merge using Excel File Using Outlook 1
N Choosing an email account during mail merge Using Outlook 3
L E-mail merge: How can I use the “Direct Replies To” option in Outlook when I’m doing an e-mail merge from Word? Using Outlook 3
A Outlook 2007 BCM mail merge Using Outlook 1
L mail merge with outlook contacts Using Outlook 2
A Should emails sent through the mail merge feature end up in my sent folder? Using Outlook 3
2 Lost attachments with mail merge Using Outlook 1
B How do I select who the email is coming from and who replies go to for a mail merge? Using Outlook 1
A Inserting an unsubsribe link a Mail merge (Microsoft word 2003) Using Outlook 1
R Outlook 2007 contacts mail merge to lables Using Outlook 3
B Mail Merge won't email Using Outlook 2
K Mail merge delivery delayed Using Outlook 1
S mail merge and cc Using Outlook 2
A E-Mail Merge to All E-Mail Addresses on One BCM Contact BCM (Business Contact Manager) 1
G VBA Interfering with Email Addresses in Mail Merge? Outlook VBA and Custom Forms 2
