Exchange 2010 sp1 mailbox, hub, cas roles and w3wp.exe / very slow
787or380
Same issue as per http://www.experts-exchange.com/Software/Server_Software/Email_Servers/Exchange/Q_26508760.html
I am running Exchange2010 SP1 latest update, w2k8 R, a dedicated server with 4 quad core processors, 16GB or RAM and iscsi 15000rpm disks. 100 users, 40 active mailboxes. After a day the Exchange is slowing down until OWA (server is busy)and RPC connections fail more and more frequently, solution, rebooting the box.
Others solution found recycling the the different Exchange apps pools every 6 hours or killing the w3wp.exe processes.
I have installed 2 fixes for 2k8 R2 memory leak but no joy. I run a perfmon and the exchange troubleshooting tools: result all ok, no bottleneck, no high disk I/O, ecetera.
The Exchange transition is finish but the 2003 is still part of the org.
Any idea?
Ranger 989
787,
How does the following counter look in the Performance Monitor in the Exchange toolbox. RPC Latency Average (msec) in the MSExchange Store Interface. Let me knwo what the numbers read.
7
787or380
No Antivirus on the box.
RPC latency around 7.100 stable on a 10mn period (9:30am, heavy traffic at the time).
7
787or380
We got some latency again, the recycling is not working.
But restarting the information store help, store.exe drop from 8GB to 2GB (this is normal), then everything works fast again, but I guess killing all the connection on the store can only help (except for the users).
I had setup a limit of 8GB for the store via AD object after I start encounter this issue but it did not help. I may lower it to 4GB making sure I still have some RAM left (16GB), because the average memory is 15.5GB on my Exchange box when the store.exe is 8GB.
On other thread I read that it could be a Domain Issue (GC), too many ldap connection on the GC, bad DNS settings? I will try rebooting my GC also DNS when the latency occur again. Then if occur again I will lower the IS usage to 4GB of RAM.
Steve Goodman
Lowering the cache for the Information Store will only increase your disk IO, it is not best practise to change this as far as I am aware. As an aside, is your page file size set to RAM+100MB?
Before you start rebooting domian controllers and such, have a look at the performance counters technet article . This should give you some idea of the values to check along with suitable thresholds. You'll even see counters for LDAP queries, which may help identify/rule out the domain controllers.
Edit: Also, have your run ExBPA on your server? Does it show any issues?
Steve
Steve Goodman
7
787or380
Hi Steve,
Thanks for replying.
EXBPA was clear of errors since the install, Perfmon values using your recommended articles were also good. (Good to know this KB).
So far so good after rebooting my recently promoted DC/DNS/GC (installed before the Exchange build) use by the Exchange2010. I had some sysvol replication issue that resolved by themself after reboot, not sure if it was the cause of my trouble. Now the physical memory is almost around 15GB but no latency, hanging or slow EMC. I kept the store.exe cache size to 8GB.
I think that Exchange2010/2007 is now using a lot more IIS and if IIS cannot get the information immediatly from a DC/GC, the all things hang!
Per example the OWA logon page was always displayed instantly but when you tried login, it hanged, maybe trying to retrieve some info on the GC, same for Outlook.
I do not believe in a memory leak in IIS anymore, I just think the Exchange app pools use a lot more ressource and have more interraction with the GC.
As an other example when closing my EMC after a day of use, one a the w3wp.exe drop from 1.2GB to 600MB.
K Backup recommendation for Exchange 2010 SP1 on Hyperv 2008 R2 Exchange Server Administration 3
F AD RMS with Exchange 2010 SP1 Exchange Server Administration 4
D Exchange Server 2010 SP1 Hosted Mode, service@ mailbox creation Exchange Server Administration 1
I Event ID 2937 after update to Exchange 2010 SP1 ArbitrationMailbox Exchange Server Administration 4
M Exchange 2010 SP1 Hosted Mode - how to move mailbox from old organization? Exchange Server Administration 1
P Journaling deployment Exchange 2010 SP1 RU1 Exchange Server Administration 1
I Event ID 2937 after update to Exchange 2010 SP1 Exchange Server Administration 8
G Exchange 2010 upgrade with SP1, language pack issue Exchange Server Administration 5
R Dynamic DNS update requirement for Exchange 2010 (SP1 RU1) on server 2008 r2 Exchange Server Administration 8
A NetBackup 7.0 configuration for Exchange 2010 SP1 Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
K Question about Exchange 2010 SP1 RU2 update Exchange Server Administration 3
J Exchange 2010 SP1 fails at Mailbox Error Unable to load exrpc32.dll Exchange Server Administration 4
D Exchange 2010 SP1 Policy to Delete mail in deleted items older than 30 days Exchange Server Administration 2
à Validating build of Exchange 2010 SP1 Exchange Server Administration 1
D Exchange 2010 SP1 topology prep error Exchange Server Administration 3
I Exchange 2010 sp1 Address Book service won't start after static RPC port reconfiguration Exchange Server Administration 2
D Installing SP1 for Exchange 2010 Exchange Server Administration 2
B Blank email list views on Outlook 2010 / 2007 with Exchange 2010 SP1 (on Citrix and Desktops) Using Outlook 7
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
P Mircrosoft Exchange 2010 SP1 Email Purge Exchange Server Administration 2
P Error 4999 after Exchange 2010 SP1 - No BES server Exchange Server Administration 12
D Upgraded to Exchange 2010 SP1 and now random Outlook clients are requesting authentication Exchange Server Administration 1
Q Don't have right permissions to assign "send as" rights in Exchange 2010 SP1 Exchange Server Administration 7
M Exchange 2010 SP1 Event id 9040 : Unable to save watermarks Exchange Server Administration 5
C Exchange 2010 SP1 "RPC can't be started because of the EMSMDB interface is already registered by Exchange Server Administration 4
N Failed Exchange 2010 SP1 Installation PowerShell "unauthorized operation" Exchange Server Administration 2
L Does Exchange 2010 SP1 update any Schema objects Exchange Server Administration 2
T After updating Exchange 2010 from RTM to SP1, OWA clients cannot move or delete emails Using Outlook 4
P Exchange 2010 SP1 Cross Site CAS connection disable Exchange Server Administration 2
A Exchange 2010 SP1 RU1 Calendar Retention Exchange Server Administration 1
M Do Database Storage Limits in Exchange 2010 SP1 affect Archive mailboxes? Exchange Server Administration 5
L Exchange 2010 SP1 Pre-Req error Exchange Server Administration 2
W Exchange 2010 SP1 Install- Required HotFixes Exchange Server Administration 3
N Second Mailbox, Mails stuck in Outbox Outlook 2010, Exchange 2010 SP1 Using Outlook 8
S Determine Managed Folder Policy for Mailbox in Powershell Exchange 2010 SP1 Exchange Server Administration 4
C Installing Exchange 2010 SP1 in a Sub domain... Exchange Server Administration 5
K Exchange 2010 SP1 RU1 - Get-PublicFolderDatabase bug / documentation issue? Exchange Server Administration 6
D Ms Exchange 2010 - Sp1 Upgrade at Prerequisites on Hub Transport Role Exchange Server Administration 8
C Managed Folder does not show up in Outlook in Exchange 2010 Sp1 Rollup 1 Exchange Server Administration 3
J After Applying Exchange 2010 Sp1 Rollup the Build numbers in EMC remain unchanged 14.1.218.15 Exchange Server Administration 1
M how to upgrade exchange 2010 to exchange 2010 sp1 Exchange Server Administration 2
