Hub/CAS dual role - load balancing query
ssssstew
Hi All
Just want someone to settle my mind on this one, if we have a dual role server which is a HUB and CAS server, am i right in that its still supported to use load balacing on this setup? So you would end up with a load balencer out front of them, then 2 x HUB/CAS dual role servers. Is this ok, I know that its not supported to cluster the HUB role, but using NLB for example infront of two of them should be ok right?
Cheers
Stewart
Stew
Santhosh Sivaraman
ssssstew
No worries, we have actually come to the conclusion that NLB in vmware is no good anyway, so we are looking at alternatives.Stew
S Change IP address of dual role Hub/CAS server? Exchange Server Administration 7
S Any system impact if change exchange 2010 CAS/HUB and Mailbox server IP address Exchange Server Administration 1
N Exchnage 2010 Hub Cas Edge Server Recovery Exchange Server Administration 3
O Exchange 2010 Hub/CAS install Exchange Server Administration 2
7 Exchange 2010 sp1 mailbox, hub, cas roles and w3wp.exe / very slow Exchange Server Administration 6
R Installing SP1 on Hub/CAS servers in CAS Array Exchange Server Administration 9
S Hub/CAS Load balance later on? Exchange Server Administration 6
T CAS/HUB Transport on VMWare Exchange Server Administration 5
J CAS/HUB server warnings for MSExchange Mailbox Replication + Event ID 1007 Exchange Server Administration 1
W Recovering CAS/HUB role server Exchange Server Administration 3
R VM 2008 R2 NLB Multicast cas/hub vip not pinging Exchange Server Administration 18
A outlook 2013 people hub :: phone button Using Outlook 1
G set exch 2010 server as the default hub transport Exchange Server Administration 6
S Hub transport ex2007 - monitoring inbound Exchange Server Administration 2
D How to manage and configure antispam updates for Hub Transport antispam filter agents at "filesystem Exchange Server Administration 1
M Upgrading HUB 2010 to SP1, getting error "There should only be a single RMS Shared Identity user" Exchange Server Administration 1
J Missing HUB DNS record results in mail piling in queue, no failover? Exchange Server Administration 2
S garbage mail recieved from Exchange 2010 HUB to Exchange 2003 user. Exchange Server Administration 2
A Hub Trasport error !!!! while exchange 2010 setup Exchange Server Administration 5
P Exchange 2010 - Enable Spam filtering on Hub Transport Server Exchange Server Administration 3
X Internal mail flow between two hub transport servers same domain Exchange Server Administration 10
S Outlook 2011 for Mac - Exchange Server address changes from public front-end to internal hub server Using Outlook 5
D Ms Exchange 2010 - Sp1 Upgrade at Prerequisites on Hub Transport Role Exchange Server Administration 8
T 451 4.4 dns query failed on exchange 2010 hub transport server Exchange Server Administration 1
K Edge to Hub to Exchange 2003 Exchange Server Administration 4
A Windows NLB for Exchange 2010 SP1 Hub Transport Servers Exchange Server Administration 7
P hub server connecting directly to FOPE? Exchange Server Administration 5
D Re: Hub Transport Role Install Fail error # 2147504141 Exchange Server Administration 0
K Edge Hub testing Exchange Server Administration 10
J Hub transporter accept all email addresses from domain Exchange Server Administration 1
H Exchange 2010 SP upgrade fails readiness check for Hub, Client and Mailbox Exchange Server Administration 7
M Exchange server 2010 installation failed with hub transport server role error Exchange Server Administration 5
J Hub Transport Rule Exchange Server Administration 6
C Safelist Aggregation on Hub Transport Exchange Server Administration 2
A Hub 2010 to Edge 2007 ( Last Error: 421 4.4.2 Connection dropped due to ConnectionReset ) Exchange Server Administration 3
Z Can I configure Safelist Aggregation Synchronization feature on Exchagne 2007 Hub Transport Server? Exchange Server Administration 1
J Autoforward from transport hub with changed sender address. Exchange Server Administration 9
S Hub Transport - Windows 2008 R2 Standard x64 - Limitations?? Exchange Server Administration 9
E Send out specific Hub Transport based on email suffix? Exchange Server Administration 3
D Exchange 2010 Failing to install at Hub Transport Role Exchange Server Administration 11
Z Hub Transport and Edge is not working as it should Exchange Server Administration 12
D Cannot remove Hub Transport role: error code 1638 Exchange Server Administration 13
L Exchange server 2010 edge to hub-transport routing error Exchange Server Administration 9
S Database is mandatory on UserMailbox error during install of Hub Transport Exchange Server Administration 19
S Dynamic Signatures? ( Hub Transport Rule? ) Exchange Server Administration 16
C Watson Error on CAS Exchange Server Administration 1
