Outlook 2010 and MobileMe - Will Not Sync Calendars and Contacts
P
patbright
I am using: Windows 7, Outlook 2010, MobileMe
My iPhone MobileMe software is not compatible with Outlook 2010 software. The calendar and contacts do not sync with MobileMe. Is there a patch/upgrade available so that I can sync my iPhone with Outlook 2010 via MobileMe?
Karl Timmermans
Outlook 2013 32 bit
Question regarding whether an update is available for any sync program should be directed to the vendor providing the sync product since Outlook is not involved in the process other than providing the data file. That said, the following thread should be of interest particularly if you are running 64bit Outlook
Outlook 2010 & Mobileme
http://discussions.apple.com/thread.jspa?threadID=2299320&tstart=-3
N
Niranjan I K
Outlook does not control any sync settings.
This is done by the sync software, for further assistance and updates for the sync software and the device, contact your device manufacturer or sync software support.
R Syncing Outlook 2010 calendar with Mobileme Using Outlook 1
D Syncing Mobileme contacts and calendars to Outlook 2010 - receive error code Using Outlook 4
V Hotmail account on Outlook 2010 Using Outlook 2
