Outlook 2007 BCM restore after removal
  • Thread starter Victor Eisenstein of PC - PC
  • Start date
V
Help!
I have a client who deleted the Business Contact Manager from Outlook 2007 (in order to speed up the computer), not realizing that ALL 800 of her contacts were in the SQL Express 2005 database. Now she can't contact her clients. She neglected to export her files to the .BCM format, so I have the files still in the SQL .MDF & .LDF format.
She also uninstalled SQL Express 2005. I at least need to pull the contact information out of these files, but I'd like to get BCM working again.
I tried re-installing SQL Express 2005, but it won't come up.
In desperation, I set up virtual PC with XP Pro using virutal PC 2007 in order to setup a "clean version" of XP w/o leftover ____ from the SQL Express & BCM un-install. Still no luck.
Any ideas?
Victor
V
Thank you Guruprasad Ra.
Now, how do I access the information contained in the SQL .MDF & .LDF files. I already gotten BCM to work with an empty contact list by doing the clean install in the Virtual XP Pro session. I tried to rename the new MSSMLBIZ sql files to NEWMSSMLBIZ, and copying the old MSSMLBIZ sql files into the same directory, and that did not work.
G
Guruprasad Ra
What is the version of Service pack installed for Office, BCM and SQL Express 2005 ?
V
In the virtual machine, I just did the basic install of MS Office Pro. No service Packs.
Outlook About says 12.04518.1014, and BCM is Ver 3.00.5828.00.
K
Keltanaka
I am in the same situation- i did not use the restore function, but I backed up the files. How do I get those linked up to my new install of bcm? I had to wipe my hard drive.
B Creating an Offline Database with Outlook 2007 BCM Using Outlook 1
J not enough memory in outlook 2007 after installing bcm Using Outlook 2
M Does a shared Outlook BCM 2007 database work with both Outlook BCM 2007 and 2010 clients? Using Outlook 2
K Marketing Campaign will not launch using Outlook 2007 with BCM Using Outlook 3
K Marketing Campaign will not launch with Outlook with BCM 2007 Using Outlook 1
D Moving from Business Contact Manager for Outlook 2007 to BCM 2010 Using Outlook 1
D Can I create a read-only user field with BCM in Outlook 2007? Using Outlook 1
D How do I synch Outlook BCM 2007 with my Blackberry and Droid Incredible? Using Outlook 1
A Outlook 2007 BCM mail merge Using Outlook 1
B BCM 2007 stop loading into Outlook 2007 Using Outlook 1
D Outlook 2007 with BCM sends blank emails. Using Outlook 0
E Outlook 2007 w/BCM crashes when I click 'tasks' Using Outlook 1
M Adding BCM to Outlook 2007 BCM (Business Contact Manager) 1
F Outlook 2007 BCM Exporting Files BCM (Business Contact Manager) 2
L How do you Recover from An Outlook 2007 & BCM Crash BCM (Business Contact Manager) 1
A Add BCM to outlook 2007 BCM (Business Contact Manager) 1
C Error when installing BCM for outlook 2007 from disk 2 BCM (Business Contact Manager) 3
B Outlook 2007 BCM will not recognize data files BCM (Business Contact Manager) 1
J BCM 2007 Shutting Down Outlook BCM (Business Contact Manager) 2
P Windows 7 / Outlook BCM 2007 Stability BCM (Business Contact Manager) 1
N Outlook 2007 w/BCM - Email issues BCM (Business Contact Manager) 5
N Email issues since installing BCM with Outlook 2007 BCM (Business Contact Manager) 1
M Outlook 2007 with BCM - Tasks being created automatically BCM (Business Contact Manager) 1
D Outlook 2007 BCM - Win 7 BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
A Outlook 2007 ca+n't find bcm BCM (Business Contact Manager) 1
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
H How to get BCM in OUtlook 2007 on Vista to detect my MDF file? BCM (Business Contact Manager) 1
D Outlook 2007 BCM SQL server problem BCM (Business Contact Manager) 1
D Outlook 2007 + BCM & SP2 - windows7 ? BCM (Business Contact Manager) 6
K Is it possible to use BCM 2003 with Outlook 2007? BCM (Business Contact Manager) 4
R BCM 2007 no longer showing up within Outlook 2007 BCM (Business Contact Manager) 3
P Outlook 2007 with BCM - Out of Memory BCM (Business Contact Manager) 13
M Outlook 2007 crashes with BCM BCM (Business Contact Manager) 1
K Moving data from Outlook 2007 to Outlook 2007 with BCM BCM (Business Contact Manager) 3
B BCM freezes Outlook 2007 BCM (Business Contact Manager) 3
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
L Outloook 2007 Ultimate BCM and Outlook Contacts? BCM (Business Contact Manager) 6
M PST import from Outlook 2007 to 2010 - Address Book contacts all in 1 group Using Outlook 3
