Outlook 2010 Crashes when right click from email
jcstone3
Every time I right click the email address in the from box - in order to save as a contact - Outlook crashes.
H
Harry Yuan
First try to start outlook in safe mode that hold ctrl key while startup. If this issue don't happen in safe mode, it may be caused by some add-ins.
Try to disable add-ins by instructions in this article. http://office.microsoft.com/en-us/help/ha100341271033.aspx
If this issue is not caused by add-ins, try to create a new outlook profile to test it.
1.Click Start, point to Settings, and then click Control Panel.
2.Double-click the Mail icon.
3.In the Mail Setup dialog box, click Show Profiles.
If you want to be able to select a specific profile each time you start Outlook, click the General tab, click Prompt for a profile to be used, and then click Add.
4.In the New Profile dialog box, under Profile Name, type a descriptive name for the new profile, and then click OK.
5.In the E-mail Accounts dialog box, select Add a new e-mail account in the e-mail options, and then click Next.
6.Click the type of server that your e-mail account works with, and then click Next.
7.Complete all of the required fields, including those that are on the tabs that appear after you click More Settings.
8.When you finish providing the required information, click Finish.
If it still not works, try to repair office by clicking Start->Control Panel->Programs and features, right click office and choose 'Change'. Then click 'Repair'.
Regards,
Harry Yuan
U outlook 2010 freezes/crashes when opening encrypted e-mails Using Outlook 0
R Outlook 2010 Crashes from the Global Address List Using Outlook 1
S Re: Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
T Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
E Outlook 2010 - Calendar crashes Using Outlook 2
D Outlook 2010 Client crashes on new message, reply, forward, send as attachment Using Outlook 3
P Outlook 2010 Crashes Using Outlook 1
P Outlook 2010 Crashes Constantly Using Outlook 4
D Outlook 2010 crashes when I select new message, reply, forward or send as attachment Using Outlook 3
L Outlook 2010 Crashes Using Outlook 1
R Outlook 2010 crashes when trying to access signature Using Outlook 1
S Outlook 2010 Crashes consistently on second reply to an email ... (Release, and not Beta version) Using Outlook 1
S Outlook 2010 consistently crashes with IMAP Using Outlook 1
E Outlook 2010 crashes, can't create new profile... Using Outlook 4
O Outlook 2010 crashes using XP SP3 Using Outlook 4
S Outlook 2010 (32bit) crashes on Windows 7 (64bit) when I view desktop Using Outlook 12
S Outlook 2010 Beta crashes quite often Using Outlook 2
J Outlook 2010 Crashes When Connected Using Outlook 2
B Outlook 2010 crashes only with mails coming from mac users and the 'Reading Pane' on__I already cancelled the add-ins in safe mode but probl Using Outlook 2
W Outlook 2010 repeatedly crashes and restarts Using Outlook 4
J Getting message crashes in Outlook 2010 Using Outlook 11
B Outlook 2010 crashes on opening Using Outlook 4
S Outlook 2010 crashes when clicking on new message or reply Using Outlook 3
B Outlook 2010 crashes at startup Using Outlook 6
P Outlook 2010 calendar crashes when opened Using Outlook 11
D Outlook 2010 crashes after clicking the reply button (second time) Using Outlook 6
B OUtlook 2010 crashes every time Reply, Repply All or Forward is pressed. Using Outlook 3
B Outlook today page crashes Outlook 2010 with default pst file Using Outlook 26
D OUTLOOK 2010 crashes trying to print any e-mail with HTML formating. Using Outlook 5
T Outlook 2010 crashes when opening certain emails Using Outlook 17
J Outlook 2010 crashes Using Outlook 11
M Outlook 2010 Crashes When Loading Add-Ins Using Outlook 6
S Outlook 2010 crashes upon opening email Using Outlook 11
E Outlook 2010 crashes when creating (reply) a message from a Meeting Using Outlook 6
