Exchange 2010 in single forest multi-domain environment
Absar
I have to transition E2k3 to E2k10 SP1. The AD desing is single forest and multiple domain. I am through running setup /pl and setup/p at forest level and found MESO and required groups has been created in forest. However I found there is another MESO in domain where E2k3 already exists and that has created confusion, should I had run /ps at forest level and /p in the domain where E2k3 already exist. Now the AD looks like
jaiz.ains - New MESO created
asso.ains - Old MESO exist with all PF and E2k3 resides in this domain.
could anyone suggest if it's ok to continue installaing exchange 2k10 or the environment is messed up, if yes how this can be fixed now.
Absar
TWHarrington
Did you run /preparedomain in the domain that contains E2K3? From the article (but read whole article for all preparation requirements):
http://technet.microsoft.com/en-us/library/bb125224.aspx
" You must run this command in every domain in which you will install Exchange 2010. You must also run this command in every domain that will contain mail-enabled users, even if the domain doesn't have Exchange 2010 installed."
Brian Day MCITP
Or you can just use /preparealldomains and get it done in one step. :)Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
Absar
to be on safer end, I re-ran /pl in domain which has E23k followed by /preparedomain, thanks to both of you.Absar
X Single AD site with DR Exchange 2010 Exchange Server Administration 6
L Exchange 2010 - Outlook 2010 multible domain on a single server Exchange Server Administration 1
M Exchange 2010 Backup in Single Server Environment Exchange Server Administration 3
M Exchange 2010 single server Environment Exchange Server Administration 3
S Recover single mailbox in Exchange 2010 Using Outlook 5
J Moving from a single Exchange 2010 server into a DAG configuration Exchange Server Administration 3
L Transitioning from a single Exchange 2003 server to Exchange 2010 Exchange Server Administration 3
A Exchange 2010 Single mailbox backup/restore by using SYmantec 2010 Backup Exec. Exchange Server Administration 1
J Forwarding mail with unresolved recipients to a single mailbox in Exchange Server 2010 Exchange Server Administration 5
P Exchange 2007 -> 2010 upgrade. Small org, single server. Exchange Server Administration 4
B Exchange 2010 Sender Filtering: How to Whitelist a single email address within Blacklisted domain? Exchange Server Administration 2
S Mail Flow to a single databse stops in Exchange 2010 without dismounting the database when log drive is full Exchange Server Administration 10
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
