OWA2010 Problem after installation of Exchange 2010 SP1 Rollup1
schedlbauerm
Yesterday I installed the rollup1 of exchange 2010 sp1.
Now I have problems with OWA 2010.
After the OWA-Login I receive the following error messages:
Outlook Web App konnte nicht initialisiert werden.
Es wurde kein Basisdesign gefunden. Das Basisdesign muss sich in einem Ordner mit einem Namen = "base" befinden.
Outlook Web App konnte den folgenden Designordner nicht laden: C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\owa\14.1.255.0\themes\violet
Die folgenden Dateien fehlen: premium.css, gradienth.png, gradientv.png, csssprites.css, csssprites.png, csssprites2.css, csssprites2.png
The english translation would be:
OutlookWebApp could not be initialised. No base design was found. The base design should be located in a directory named "base".
On the exchange server the eventids are 26 and 116. The event source is 'MSExchange OWA'.
Kind regards,
Martin
Tino Donderwinkel [MVP]
Please confirm that the custom theme you are using ('violet') is present at the location mentioned;
Could be that the theme is in 'another' themes location like;
C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\owa\<previous version>\themes\violet
You can simply copy the theme to the correct location.
Furthermore, check if the correct permissions are set on the theme's folder.
Tino
AndyD_ [MVP]
When you ran SP1 RU1 originally, did you run it as an elevated account?
schedlbauerm
I ran it as part of windows update. I'm not sure if this means that it runs as an elevated account.
R OWA2010 How to search for appointments? Using Outlook 1
D Disable conversation view by default? (OWA2010) Exchange Server Administration 1
B Problem with import Excel BCM (Business Contact Manager) 1
chupacabra Problem with IMAP .pst file Using Outlook 13
deonholt Address Book problem and created new profile ... Using Outlook 1
