Outlook 2007 Events disabled by WMDC -- Fix??
Ron Rosenfeld
It seems that if Outlook 2007 is started up by the Windows Mobile
Device Center, Outlook Events are disabled.
I have an ItemSend event in ThisOutlookSession that has been working
intermittently. I have also tried using it in a Class module with
similar results. (It changes the Subject line depending on the
original Subject line contents).
For testing purposes, I added a Startup event to ThisOutlookSession.
Private WithEvents myOLApp As Outlook.Application
Set myOLApp = Outlook.Application
Stop
And then, when the VBA code Stops, I place a break point in the
ItemSend event code.
If I startup Outlook normally, the Stop statement gets executed, and
my subsequent ItemSend event code also seems to be triggered normally.
However, if I start the Windows Mobile Device Center, which syncs with
my Dell Axim, it will, in turn, start up Outlook. Although Outlook
starts up, the Stop statement does NOT get executed, and subsequent
ItemSend events do NOT trigger anything.
Is there anything I can do to correct this? Or must I remember to
always start Outlook first?
H
Harry Yuan
Please set the Macro security to run all macros. Why you want to use Stop in VBA code?
Please comment this line, and see if this VBA code could be called.
Here are some resources about this topic. Wish they could help you.
Application_Startup doesn't seem to work - Outlook 2007.
Application_Startup event not firing.
If you have any concern on this topic, just feel free to follow up.
Regards,
Harry
Ron Rosenfeld
I had already done that. And the macros run fine EXCEPT when Outlook
is started by WMDC.
I've used it for troubleshooting auto open and startup macros, since
it is an easy way to set a break point for these kinds of event
macros. In this case, it was just to see if the code was being run.
Application_Startup doesn't seem to work - Outlook 2007 <http://www.eggheadcafe.com/software...artup-doesnt-seem-to-work--outlook-2007.aspx>.
Application_Startup event not firing <http://www.devnewsgroups.net/officedev/t26535-application-startup-event-not-firing.aspx>.
Neither is applicable to my problem. But thanks as it added to my
knowledge.
C Outlook 2007 only displaying all day events in a month view Using Outlook 2
D Missing Hotmail Calendar Events in Outlook 2007 Using Outlook 3
S Catch events from pre-existing buttons in Outlook 2007 Outlook VBA and Custom Forms 7
A how to capture outlook 2007 events Outlook VBA and Custom Forms 4
C Why does Outlook 2007 generate 3 events for 1 single "Add"? Outlook VBA and Custom Forms 6
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
L Outlook 2007 - Macro Re Search Using Outlook 16
D Outlook (Office) 2007 & Windows 10 Pro Using Outlook 6
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
P How to switch back from Outlook 2010 to Outlook 2007? Using Outlook 3
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
