Change 'Mark As Read' Status Without using Reading Pane
jfain
I'm using Outlook 2010 and have inbox view configured as Preview and Reading Pane is off. However, messages remain unread (bold) until I double click them or manually change them to 'read'. How can I get the message status to change to 'read' without using the Reading Pane?
Well, technically, its not read if you don't preview or open... :) You'll need to use Ctrl+Q to mark them read without reading. Or right click on a folder and choose mark all read. If you need everything marked read, or at least ones that meet certain conditions, try a rule.
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 3
B Change from Address Outlook VBA and Custom Forms 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
B See "Change View" Drop Down as a List? Using Outlook 1
R Folder pane width change Using Outlook 52
P How can I change my calendar view back Using Outlook 3
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
W Appointment occurrences change the location property Using Outlook 0
T Scheduled footer change Using Outlook 2
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
CWM030 Name Change? Exchange Server Administration 9
C Change Subject Line in Selected Emails Outlook VBA and Custom Forms 1
B Do not change the From address in Outlook Templates Using Outlook 0
M Sudden change in From field - now very short Using Outlook 4
M cannot change delivery folders with IMAP accounts Using Outlook 0
S Email Format With Embedded Images and Tables Change Using Outlook 2
I change subject and forward without FW: Outlook VBA and Custom Forms 4
Rupert Dragwater Can't change font size Using Outlook 5
tjd189 outlook 2016 name change Using Outlook 1
E Button to change subject Outlook VBA and Custom Forms 1
D Office365 Conference Room name change? Using Outlook 5
J Change POP account to Forwarder - What happens in Outlook? Using Outlook 2
C Change default colors for conditional formatting Using Outlook 2
K Other Shared Calendar on Outlook cannot change items Using Outlook.com accounts in Outlook 7
Diane Poremsky How to Easily Change the Private Flag New Slipstick.com Articles 0
Diane Poremsky How to Change the Font used for Outlook's RSS Feeds New Slipstick.com Articles 0
R Outlook 2016 - How to change password in MS Exchange email client Using Outlook 0
