Customize accounts (folderlist) in navigation pane
w84dre
I have two accounts in the navigation pane: a POP and an Imap. The POP (Personal folder) is on top of the list. I want to customize these as such that the second account (IMAP) wil be positioned on top of the list and the personal folder second.
I've been digging the web for two days and didn't find any answer. Not sure if it's possible at all.
Forum Admin
The folder list is in alphabetical order following the default message store or account on top. Normally its one and the same, but IMAP past can't be default, so the local pst should be on top. You can try changing the pst display names so the personal folder comes after the imap alphabetically but I'm pretty sure imap will stay below the local pst. (right click on top level folder in navigation pane, choose properties, then advanced and type a new display name)
w84dre
For some reason my reply disappeared. Try again...
You're right.
I changed name of Personal Folders to the accountname (e.g. z-accountname) and it didn't change the sequence in alphabetical order. Default account (POP3) remains on top. Reason to switch both accounts was that the folderlist of the "old" POP account pushes the new account - used for non personal mails - (half) off the pane. I prefer to see the both (new account and folderlist).
Forum Admin
Are you using the Mail navigation pane? Add your most used folders to the favorites list so you don't need to use the folder list. You can arrange the folders in the order you prefer.
w84dre
Yeap I do.
Before, my two pop accounts shared same inbox and a bunch of folders were used to organize my e-mails. It's easy archiving. My business account changed using Imap, as such that my smartphone (BB) could receive e-mails when i was out in the field. However I left my folders in the list of the "left over" pop account, so that I still can use my folder structure. Old fashioned, but it works very easy (Gmail server maintains a copy as well).
Will copy most used folders to favourite and collapse the pop account.
Thanks for your help
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
J Customize Attachement Security Warning Using Outlook 1
M Customize Comments / Notes Section time stamp on Contact Records BCM (Business Contact Manager) 0
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT New Slipstick.com Articles 0
M Customize CreateItemFromTemplate Macro Outlook VBA and Custom Forms 2
Ankit Agrawal Customize themes in outlook 2010 Using Outlook 1
M please customize this code Using Outlook 1
G Customize Outlook Today folder Using Outlook 0
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
P How may I customize with an own immage a standard email Using Outlook 6
D In Outlook 2007 on Windows 7 64 bit Customize Current View 'Other Settings' Fonts changes do not hold Using Outlook 2
K Can I customize OL2010 month view calendar to be more legible; skip confusing colors and show more a Using Outlook 1
J Customize Outlook view to fit Smartphone display via i.e. Citrix Receiver ? Using Outlook 1
M Customize Current View of PST Files Using Outlook 2
P Customize Appointment Form Using Outlook 1
U How to customize exch 2010 smtp bounced msg like 5.7.1 or 5.7.11 Exchange Server Administration 2
S Customize Text on OWA Change Password Form Exchange Server Administration 3
J How to customize the To-Do list to show items from only one specific mailbox? Using Outlook 2
J The filter Button is dimmed in the View - Customize Current View dialog. Using Outlook 2007 on Exchange. Using Outlook 3
C Customize Themes Exchange 2010 SP1 Exchange Server Administration 4
R customize contacts Using Outlook 1
K OWA 2010 - Any way to customize the Calendar Sharing Invitation? Exchange Server Administration 1
A Customize Colours Using Outlook 1
G BCM 2007 Customize Current View not sticking Using Outlook 2
C Customize Current View - Group By & Remove This Column Using Outlook 2
A when i customize new fields in the contact menu, it displays under define fields but does not display when trying to imput a new contact. Using Outlook 1
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
R How to implement customize toolbar in outlook? Outlook VBA and Custom Forms 1
N How to add fields to customize reports in BCM? BCM (Business Contact Manager) 3
R Outlook 2010 How do you export 2 email Accounts' 2010 Inbox Files to new computer (2019)? Using Outlook 1
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
T why are the calendar icons different for different accounts Using Outlook 2
Martull Forced signature when multiple accounts exist Outlook VBA and Custom Forms 4
A Microsoft Personal vs Work Accounts in Outlook Using Outlook.com accounts in Outlook 7
