Contact categories problem when upgrading from 2007 to 2010 Outlook
I
ITFT
I recently upgraded from Office 2007 to 2010, and most of my Outlook data migrated fine - email, calendar, etc. However, my contacts are not working correctly. I can only use Business Card, Card, or Phone views - when I try list view it give me an error that " Outlook cannot display this view" with no other information.
System information: Windows 7 Enterprise. 1900+ contacts, each of which is in one of 100+ categories (so re-entering any information by hand is mostly out of the question).
Here's what I've tried to fix it:
1. Create a new Mail profile, run scanpst.ext on the old .pst and then import just the contacts data from there. The same problem happens as before.
2. Export contacts as a CSV and re-import them into a new Mail Profile. This got list view to work, but when I tried to sort them by category, the program would freeze.
3. Since it seemed to be a problem with my category data, I cleared that column from the CSV and imported again. This time everything worked fine, except that I didn't have my category data.
4. So, now that it's been narrowed down to categories, I took a closer look. Office 2010 seems to use color categories, whereas I have named categories without color (business, personal, clubs, etc - around 100 categories I've named). I tried right-clicking on my profile in Outlook and going to " convert to color categories," but that made my contacts completely inaccessible - it would give the same " cannot display this view" for every view type.
And now I'm stuck. I reinstalled Office 2007 and imported from the .pst into a new profile, and all my contacts and categories just work, no problems at all. So, it's something about 2010 that's not importing them correctly. Has anyone else experienced this issue? Please help!
Brian Tillman
Try avoiding export and import. Open your existing PST in the new Outlook. In fact, when you upgrade from Outlook 2007 to 2010, that usually happens automatically. Then upgrade to color categories. That will add your existing categories to your Master Category List. You'll then be able to assign the colors you want to them. I've done it. In fact, Outlook 2007 uses the same approach - color categories. If you open your PST in Outlook 2010, you should see the same categories and colors you saw in Outlook 2007. See: How categories and calendar labels from earlier versions are updated for Office Outlook 2007.
Z Outlook.com Contact categories Using Outlook 8
J Contact page too large for screen. Can't see categories, etc. Using Outlook 1
P Searching By Contact Categories Using Outlook 0
D Rules Based on Contact Categories Using Outlook 2
P Contact Categories Using Outlook 1
B synchronizing categories of contacts between outlook 2010 and business contact manager Using Outlook 1
M Setting up Mail Groups based on Contact Categories Using Outlook 6
N Outlook categories for Business contact manager BCM (Business Contact Manager) 2
A Sending contact vcards sends older version instead of updated version Using Outlook 4
M Contact photos are distorted Using Outlook 0
C Outlook Contact Manager - A viable successor? BCM (Business Contact Manager) 7
N Contact display as Using Outlook 2
N How to turn off autocorrect in contact notepads Using Outlook 2
P AGGGGHHHH!!!! - Address Books and Contact Subfolders Using Outlook 5
G Mass Updating Contact form used Outlook VBA and Custom Forms 8
Rupert Dragwater How to import contact list Using Outlook 15
T One Contact list, two sections of company (none) Using Outlook 2
M regarding legacy contact cards Using Outlook 2
L OL 2016 contact: is there a way to prevent an admin from mistakenly deleting a contact? Using Outlook 1
D Customized Contact Form Losing UDFs. Outlook VBA and Custom Forms 12
E Imported Contact Issues Using Outlook 11
K Contact notes field replicating Using Outlook 6
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
