My Calendar appointments are not being saved
anewlovejoy
My Calendar appointments are not holding after setting. I enter them, but when I go back to my email message, the events are not recorded.
I click "done" after entering information, but it is not sticking.
Judy Gleeson - MVP Outlook
If you could please explain a bit more clearly whay you are doing, that may be helpful. You haven't explained how the email and the calendar relate to each other in your scenario.
It's not clear to me what you mean when you say you go back to the email message (is that a Meeting Request???) and the "events" (are they Events or is that your personal terminology??) are not recorded.
Also, where's the "done" button you describe?
Regards Judy Gleeson, Canberra, Australia www.linkedin.com/in/judygleeson
G
Ganesh Kumar N
Are you able to save or create a new contact or task?
What type of email account do you use? (e.g., POP, IMAP or exchange)
Which version of outlook do you use?
Ganesh Kumar N
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
N Gathering Calendar Appointments from Calendars that synced as Contacts Exchange Server Administration 1
R Make past appointments remain in calendar Using Outlook 1
T populate calendar with appointments and send reminders Using Outlook 1
Diane Poremsky Copy New Appointments to Another Calendar using VBA New Slipstick.com Articles 0
Diane Poremsky How to Import Appointments into a Group Calendar New Slipstick.com Articles 0
A Looping appointments in calendar Outlook VBA and Custom Forms 0
B Outlook Calendar/setting appointments Using Outlook 1
F Outlook 2007 Calendar Appointments not in Outlook Today view Using Outlook 11
N Outlook Shared appointments automatically to Private Calendar Using Outlook 1
A Synchronize Access Table with Outlook Calendar Appointments Outlook VBA and Custom Forms 3
I Adding appointments/tasks to other user's calendar Using Outlook 1
R Getting a colleagues appointments and calendar entries Using Outlook 1
Katrina Fox Missing appointments on calendar even though transferred from old pst Using Outlook 0
Horsepower Setting appointments in calendar Using Outlook 3
A OL13 Calendar, won't allow entering 2 appointments consecutively Using Outlook 4
R New computer, OL2010 unable to display shared calendar appointments Exchange Server Administration 3
C Calendar is not accepting Appointments Using Outlook 0
A Suggestions on ways to let apps create appointments in any user's calendar? Exchange Server Administration 0
D Priting only Recurring Appointments in Outlook Calendar 2010 Using Outlook 1
L Shared calendar appointments received as emails, stays in inbox! Using Outlook 1
Z Calendar Appointments Using Outlook 1
G Can't see all my appointments on Outlook calendar Using Outlook 2
R Copy Appointments to Another Exchange Calendar Using Outlook 23
Horsepower Default calendar to receive email appointments Using Outlook 5
J Calendar Appointments move when Computer Time Zone changed. Using Outlook 5
U Appointments items not showing in calendar Using Outlook 2
A Delete all appointments on calendar for week of holiday / annual leave Using Outlook 1
J Default Category foo Calendar Appointments Using Outlook 1
M Outlook Calendar Monthly View Missing Appointments Using Outlook 3
D appointments on To Do Bar don't reflect the correct Calendar Using Outlook 3
R Shared Public calendar folder changing appointments Using Outlook 1
S exceptions to recurring appointments in calendar Using Outlook 1
K Calendar Appointments after a change of Domain Controller Exchange Server Administration 0
L Block others from inserting appointments in your calendar Using Outlook 3
F Outlook Calendar is "dropping past appointments" Using Outlook 1
J Can not change own calendar appointments Using Outlook 3
E calendar appointments Using Outlook 1
A Outlook 2007 won't show appointments/meetings in calendar on actual date, only on date appt/mtg made Using Outlook 1
A Creating appointments in shared calendar Using Outlook 1
H Calendar not updating accepted appointments! Using Outlook 1
W Reformatting calendar; removing creator name from appointments Using Outlook 3
J Cannot see calendar appointments for Outlook 2007 Using Outlook 1
O Outlook calendar view changes from 'Day/View/Month' to 'All Appointments' automatically Using Outlook 2
A The Calendar is not listing appointments Using Outlook 2
I Outlook 2010: Appointments not visible in shared calendar if free/busy is set to Free. Using Outlook 2
D Old recurring appointments showing up in Calendar Printing Assistant Using Outlook 6
