Distribution Lists, Selecting members, filtering members out of the selection process (not one by one)
Trophyson
I am trying to creat distribution lists. I select ALL of my contacts and add them to the list then one by one I have to erase the ones I dont want on the list. Is there a faster way to get this done?
I have approximately 3000 contacts and only want the ones that have email addresses in the contact listings. How can I do this other than selecting them one at a time and hitting delete??
Please help and thank you in advance
Russ Valentine
The Select Members dialog for a DL is the Outlook Address Book view, which contains all electronic addresses. Your post is vague. Why would you create a DL by selecting all your Contacts and all their electronic addresses? Why not select just the ones you want?
Be advised, that DL's are a deprecated feature that do not work reliably. No DL should ever contain more than a handful of addresses. Microsoft wants us to use Categories now instead of DL's.
Russ Valentine
E Distribution lists Using Outlook 1
Diane Poremsky Using Categories for Dynamic Distribution Lists New Slipstick.com Articles 0
Diane Poremsky Find the Distribution Lists a Contact Belongs to New Slipstick.com Articles 0
T Missing sub-contact folders (distribution lists) Using Outlook 3
M Nested distribution lists: how to count UNIQUE # of people... Outlook VBA and Custom Forms 13
C Office 2007 Distribution Lists Using Outlook 1
A Why doesn't distribution lists update automatically Using Outlook 3
K outlook 2007 Export/Import Distribution lists Using Outlook 1
N Personal Distribution Lists Using Outlook 0
T outlook 2010 'not enough memory avaliable to perform the operation' with distribution lists Using Outlook 0
T outlok 2010 'not enough memory avaliable to perform the operation' with distribution lists. Using Outlook 3
8 Distribution Lists Using Outlook 1
T Configuring Distribution Lists in Exchange 2010 Exchange Server Administration 3
D Users migrated from exchange 2003 cannot manage Distribution lists from Outlook Exchange Server Administration 7
K Issue with Distribution Lists in Outlook 2007 Using Outlook 2
D Export Distribution Lists or Groups from Contacts Using Outlook 3
D Outlook 2010 Client - "unable to connect to retrieve additional data" for some Distribution lists Exchange Server Administration 7
J Audit distribution lists changed via OWA Exchange Server Administration 4
M Distribution lists not working, outlook will not open properly and email stuck in outbox. Using Outlook 3
B Owners cannot update distribution lists or groups after Exchange 2010 migration Exchange Server Administration 2
D extra names showing up in distribution lists Using Outlook 2
A Nested distribution lists in shared folders don't work? Using Outlook 3
T Customizing Fields in Distribution Lists Using Outlook 1
I email distribution lists, hiding all the email addresses in it Using Outlook 2
B Managing Distribution lists from AD users and computers in Exchange 2010 Exchange Server Administration 1
P How to delete inidividuals from distribution lists when using OWA? Using Outlook 1
S Increase the size of distribution lists in OWA? Using Outlook 2
Z Outllook 07 Distribution Lists show up as different distribution list Using Outlook 1
L How do you remove duplicate contacts when sending an email to multiple distribution lists? Using Outlook 2
A Combine distribution lists in Outlook 2010 Using Outlook 2
P regarding distribution lists Using Outlook 2
E Distribution lists too big! Cant figure out how to devide into smaller ones. Using Outlook 8
S Distribution Lists for Outlook 2007 Using Outlook 2
J Rights to modify all distribution lists Exchange Server Administration 3
S Meeting invites to distribution lists going into calendars with wrong duration Using Outlook 1
L Exporting distribution lists to excel Using Outlook 1
A Do unlimited distribution lists created in Outlook 2007 SP2 work in OWA 2003? Exchange Server Administration 3
A How can I see which personal distribution lists a contact is a member of? Using Outlook 3
T In Outlook Contacts - I am only seeing my distribution lists. Using Outlook 2
J Fixing the Exchange aliases on public folders, distribution lists, and for mailboxes Exchange Server Administration 1
P Distribution lists stopped working Using Outlook 2
J Managed by property for Distribution Lists Exchange Server Administration 3
P Editing Multiple Distribution Lists Simultaneously? Using Outlook 3
R How do I expand all distribution lists in the To: section? Using Outlook 4
J Counting addresses in distribution lists Using Outlook 4
R Adding members to outlook distribution lists Outlook VBA and Custom Forms 4
E Using rules with personal distribution lists Using Outlook 5
A Distribution Lists in Business Contact Manager BCM (Business Contact Manager) 1
