outlok 2010 'not enough memory avaliable to perform the operation' with distribution lists.
TimFoo
I'm upgrading from outlook 2003 to outlook 2010 and have several distribution lists I would like to merge into one. When I try to save the new list (containig about 500 members) while in cached exchange mode I get the following message as a conflict
13:41:31 Synchronizer Version 14.0.4760
13:41:31 Synchronizing Mailbox 'Tim Fookes'
13:41:31 Synchronizing local changes in folder 'Contacts'
13:41:31 Uploading to server 'seuk-s5.seuk.sterlingenergyuk.com'
13:41:31 Error synchronizing message 'BCC Only'
13:41:31 [8007000E-50C-3F1-323]
13:41:31 There is not enough memory available to perform the operation.
13:41:31 Microsoft Exchange Information Store
13:41:31 For more information on this failure, click the URL below:
13:41:31 http://www.microsoft.com/support/prodredirect/outlook2000_us.asp?err=8007000e-50c-3f1-323
13:41:31 Moved a message that failed synchronization to 'Local Failures'. Message subject -> 'BCC Only'. You can view this message in your offline folder only.
13:41:31 Done
I get a similar message about lack of memory when not in cached exchange more. I thought this was a problem that was only in outlook 2003 and 2007 SP1 ? Am I missing something ? As I can create large groups via web access...
Thanks foy any help
Tim
E
Ezil Vinoth
What type of email account has been configured (POP or IMAP or Exchange)?
Are you trying to merge all distribution list in Outlook 2003 or 2010?
Instead of merging all distribution lists, create new distribution list to add all the contacts and verify the status.
There is a limit in number of contacts that you can add in one distribution list to send emails. Check the link below, might be helpful.
http://office.microsoft.com/en-us/outlook-help/create-and-edit-a-distribution-list-HA010205427.aspx
Also check with the link below.
http://support.microsoft.com/kb/238569
TimFoo
The original distribution lists were made in outlook 2003, but the new one has been made in 2010, and was made from scratch...
Its an Exchange account.
And sadly there was nothing of any help in those links. Any more ideas ? As its only a small list...
F viewing cox emails on outlok 2010 and want deleted from cox when viewed on outlook 2010 Using Outlook 1
T outlok.com using MS Outlook Using Outlook 6
J "Outlok like" control - users(contacts) resolving Outlook VBA and Custom Forms 11
S Outlok 2007 add-in PJ Correspondence Log-How do I get it loaded? Using Outlook 7
C "Name on the Security Certificate is Invalid or Does not Match..." using Outlok 2007 w/ Exchange 200 Using Outlook 59
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
R Outlook 2010 How do you export 2 email Accounts' 2010 Inbox Files to new computer (2019)? Using Outlook 1
F how do i set a reminder in onenote 2010 Using Outlook 8
