Inbox contents disapear on open.
Brian Tillman
Check the view you're using. If necessary, reset all views by running Outook once with the /cleanviews command switch. Press WinKey+R. In the Open field, enter
outlook.exe /cleanviews
Be sure to include the space. Press Enter.
Sanacinto
I tried that and no change. I can get the emils back by doing a search and following that withn a searc for eveything, and they apear until I close and open outlook.
G
Guruprasad Ra
Try resetting the views and verify the results:
Open Outlook > Click on inbox > View > Reset view
H Outlook 2010 moves entire inbox contents to deleted items folder Using Outlook 15
E Inbox has stopped showing contents Using Outlook 1
L desperate to restore inbox contents. thanks Using Outlook 6
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
E Outlook 2016 Inbox search bug Using Outlook 1
LolaArrabal My huge inbox folder Using Outlook 2
M Emails being sent to Inbox and IPM_Subtree Using Outlook.com accounts in Outlook 4
S Accepting meeting request from calendar keeps the meeting request in the inbox Using Outlook 2
E Inbox field customization Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
Diane Poremsky Category Color doesn't Display in Inbox New Slipstick.com Articles 0
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
A Can't add a column called "name" to Inbox? Using Outlook 1
V Not displaying newest messages in Inbox Using Outlook 10
