Outlook 2007 once closed will not reopen must use task manger and end process
  • Thread starter golfingfrenchie
  • Start date
G
golfingfrenchie
Every time I close Outlook, and go back to the menu bar and try and open it, there is no action.
I must go into the task manager and end the Outlook.exe process. Then it will work properly. I can send and receive messages with no other issues.
P
Palcouk
Generally caused by integrated Anti Virus, a sync app or other third party add-ins
Raju S Das
Try opening outlook in application safe mode and check if the issue occurs. To open outlook in application safe, click start > All Programs > Microsoft Office > Press and hold the Ctrl key and click "Microsoft Office Outlook 2007". If everything works fine in outlook safe mode, then disable the add-in(s). For information on disabling add-in(s) in outlook check the Microsoft link below:
http://office.microsoft.com/en-us/outlook/HA100341271033.aspx#9
If this step did not work, create a new profile for outlook and then check if it resolves your issue. Click here for information on creating outlook profiles
P Changing all email signatures (font, color) at once in outlook 2007 Using Outlook 2
S Outlook 2007, opens once....but will not reopen Using Outlook 1
S Re: Outlook 2007 won't re-open once closed Using Outlook 1
W Cannot launch Outlook 2007 properly; once launched, the menu items do not work properly. Using Outlook 1
0 not able to open Outlook 2007 .msg files more then once Using Outlook 1
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
L Outlook 2007 - Macro Re Search Using Outlook 16
D Outlook (Office) 2007 & Windows 10 Pro Using Outlook 6
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
P How to switch back from Outlook 2010 to Outlook 2007? Using Outlook 3
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
