OL2007/XP views will not retain settings. Really need some help here.
seprice
ok...i'm back where i started. this is a continuation of a previous thread...hoping i'll get some additional support:If i use a standard view for messages or tasks, and i sort it or group it, it will retain those settings until i reset it in the custom view box.
outlook profile keeps corrupting even after creating new profile
wheni build a custom view, (and uncheck the group by arrangement box), if i make any sort of "on-the-fly" change like sort or group, the custom view will maintain the new change.
i've tried several different options and arrangements, closed and restarted, rebooted, .... still happens.
Do I have an incorrect perception of views? Seems to me that the "simple list" view, especially as it is a system view, should remain consistent all the time...if you re-sort, it should return to its official set-up next time you select that view.
what is the point of having standard or custom views if they are not "permanent?" or why have columns that can sort, if you can't put them back the way they were?
I'm going to post this as a new post, hoping i'll get some additional suggestions.
seprice
I don't know why the font turned out like that....
ok...i'm back where i started. if i use a standard view for messages or tasks, and i sort it or group it, it will retain those new settings until i reset it in the custom view box.
When I build a custom view (and uncheck the group by arrangement box), if I make any sort of "on-th-fly" change like sort or group, the custom view will maintain the new change.
I've tried several different options and arrangements, closed and restarted, rebooted, new profiles, even complete uninstalled and reinstalled Office 2007...still happens.
Do i have an incorrect perception of views? Seems to me that the "simple list" view, especially as it is a system view, should remain consistent all the time. If you resort it, it should return to its offical set-up next time you select that view.
What is the point of having standard or custom views if they are not "permanent?" Or why have columns that can sort, if you can't put them back the way they were?
This is my previous post and all the attempts I've already made: "Outlook profile keeps corrupting even after creating new profile."
P
Priyalatha Narayan
Manually uninstall and reinstall Outlook.
1. Start -> Control panel -> Add and Remove Programs -> Office 2007 (Outlook 2007 if Outlook is a standalone product) -> Right click -> Change-> Add or remove features -> Click on the drop down near outlook and click “Not available"
2. Click on Start-> Run -> Type “regedit".
3. Right click on Computer-> Export-> File name “Registry backup"-> Save
4. Expand computer-> HKEY current user-> software->Microsoft-> Office-> Outlook
· HKEY current user-> software->Microsoft-> Office->12.0>Delete “Outlook " if you find
· HKEY current user-> software->Microsoft-> Office->11.0>Delete "Outlook” if you find
· HKEY current user-> software->Microsoft-> Office->10.0>Delete "Outlook” if you find
5. Collapse HKEY Current user
6. Expand HKEY Local machine -> software->Microsoft->Office-> Outlook
· HKEY Local machine -> software->Microsoft->Office->12.0>Delete “Outlook “if you find
· HKEY Local machine -> software->Microsoft->Office->11.0>Delete "Outlook” if you find
· HKEY Local machine -> software->Microsoft-> Office->10.0>Delete "Outlook” if you find
7. Close Registry Editor
8. Control panel -> Add and Remove Program -> Office 2007-> Right click -> change-> Add or remove features -> Click on the drop down near Microsoft Office and choose " Run all from my computer" -> install now.
9. Restart the computer and check if the issue persists.
E OL2007 on Exchange: opening OL on different computers Using Outlook 1
R Multiple instances of OL2007 and creating rules Exchange Server Administration 1
P OL2007 -- All day appt. end time is "tomorrow" Using Outlook 3
T Search for multiple contacts in OL2007 Using Outlook 3
D OL2007/Exch2003 multiple replies using out of office Using Outlook 1
A autodiscover issue with OL2010 but no issue with OL2007 Exchange Server Administration 10
B Inability of changing drafts folder in OL2007 Using Outlook 1
M How to disable OL2007's junk mail filter? Using Outlook 2
M OL2007 doesn't properly shut down. Always hangs at next restart... Using Outlook 1
T Prevent Task Accepted and task update messages from deleting in Task OL2007 inbox. (I received a task update message in my Inbox, but it disappeared.) Using Outlook 7
T Prevent Task Accepted and task update messages from deleting in Task OL2007 inbox. (I received a ta Using Outlook 5
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
M OL2007 Add-in won't install on OL2010 Outlook VBA and Custom Forms 1
P Embed Word doc w/form into OL2007 form Outlook VBA and Custom Forms 1
N Right-click an address -> add to BCM? [OL2007] BCM (Business Contact Manager) 1
J Deploying OL2007 Add-In Outlook VBA and Custom Forms 3
A How to replace getcontactsfolder (ol2007) in Outlook 2003 Outlook VBA and Custom Forms 2
P Redemption not working on OL2007 Outlook VBA and Custom Forms 2
A Connect to server to views items Using Outlook 0
J Office 365 erased all of my task views Using Outlook 3
Jennifer Murphy To Do List Views Using Outlook 0
S Views ans Where Settings AreSavd Using Outlook 4
avant-guvnor Outlook 2016 and views, categories etc. Using Outlook 3
witzker Change icon for custom views Using Outlook 1
Z Batch Change Folder Views in Outlook 2016 Using Outlook 1
P Duplicate Standard Views Using Outlook 3
H User designed fields not usable in contact folder views Using Outlook 0
piusg 2013: Task Views keep disappearing Using Outlook 4
Brian Outlook List of custom task views missing in OL2013 Using Outlook 2
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
J Calendar Views (2013) are Blank Using Outlook 1
R Filter Views by Category Using Outlook 2
S How do I get the default Outlook 2007 Contacts Views back? Using Outlook 3
T save custom user settings/ views BCM (Business Contact Manager) 2
L Outlook 2007 Macro For Views Using Outlook 10
A lock task views? Using Outlook 11
M Apply different views to calendars Using Outlook 0
D Cannot delete shared contact or calandar from views Exchange Server Administration 1
B OWA Calendar Views not available Exchange Server Administration 2
A In Contacts Phone List View, allow alpha jump w/single key, same as Card views Using Outlook 4
D Zoom in Microsoft Outlook Views? (Not Messages) Using Outlook 2
D Views with the ToDo Bar and Navigation Pane Using Outlook 1
J Export custom views from offline OST Exchange Server Administration 4
J How to disable syncing folder views/layouts Using Outlook 5
C User defined field not found in any views prints. Cannot locate to delete. Using Outlook 2
M Outlook 2010 - Contact Views: Why can I not view my contacts by typing in the last name? Using Outlook 15
B Blank email list views on Outlook 2010 / 2007 with Exchange 2010 SP1 (on Citrix and Desktops) Using Outlook 7
F Outlook 2007 custom views do not show emails with Exchange 2010 Server Exchange Server Administration 2
