Customize Outlook view to fit Smartphone display via i.e. Citrix Receiver ?
Jano59
Hi there
Anyone here with an way to customize PC Outlook to fit on a say Windows Mobile phone, could be like 3 phone displays wide horizontal but divided up into 3 logical displays, i.e. 1st folders, 2nd Folder contens, 3rd E-mail message view...
We plan to use Citrix Receiver on smart phones, so it could be use-full to have a ready made views in Outlook that kinda fits on smart-phone displays.
Remove tool-bar or customize it to only have a few buttons then remove title, menu and status bar. Remove not so use-full panels etc.
I can see Outlook 2007 is capable to do some of the above via the View Menu inside Outlook.
We use Windows/Outlook/Office 2003 via Citrix XenApp 5.
Turning off many of outlook's features is done using a registry key, so you can do it using policies - you can use the navigation pane, the message list and the reading pane but will probably want to turn off the To-do bar. But you'll have 1 outlook window, not 3 separate ones It'll either be really tiny or you'll do a lot of scrolling.
D In Outlook 2007 on Windows 7 64 bit Customize Current View 'Other Settings' Fonts changes do not hold Using Outlook 2
J The filter Button is dimmed in the View - Customize Current View dialog. Using Outlook 2007 on Exchange. Using Outlook 3
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT New Slipstick.com Articles 0
Ankit Agrawal Customize themes in outlook 2010 Using Outlook 1
G Customize Outlook Today folder Using Outlook 0
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
R How to implement customize toolbar in outlook? Outlook VBA and Custom Forms 1
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
J Customize Attachement Security Warning Using Outlook 1
M Customize Comments / Notes Section time stamp on Contact Records BCM (Business Contact Manager) 0
M Customize CreateItemFromTemplate Macro Outlook VBA and Custom Forms 2
M please customize this code Using Outlook 1
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
P How may I customize with an own immage a standard email Using Outlook 6
K Can I customize OL2010 month view calendar to be more legible; skip confusing colors and show more a Using Outlook 1
W Customize accounts (folderlist) in navigation pane Using Outlook 5
M Customize Current View of PST Files Using Outlook 2
P Customize Appointment Form Using Outlook 1
U How to customize exch 2010 smtp bounced msg like 5.7.1 or 5.7.11 Exchange Server Administration 2
S Customize Text on OWA Change Password Form Exchange Server Administration 3
J How to customize the To-Do list to show items from only one specific mailbox? Using Outlook 2
C Customize Themes Exchange 2010 SP1 Exchange Server Administration 4
R customize contacts Using Outlook 1
K OWA 2010 - Any way to customize the Calendar Sharing Invitation? Exchange Server Administration 1
A Customize Colours Using Outlook 1
G BCM 2007 Customize Current View not sticking Using Outlook 2
C Customize Current View - Group By & Remove This Column Using Outlook 2
A when i customize new fields in the contact menu, it displays under define fields but does not display when trying to imput a new contact. Using Outlook 1
N How to add fields to customize reports in BCM? BCM (Business Contact Manager) 3
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 0
M Outlook 2016 Outlook randomly unhides from taskbar Using Outlook 0
D Sending email from Office 365 alias in Outlook Using Outlook 4
B Spam folder not showing in Outlook Using Outlook 5
ThinkToday Calculate reply time of outlook mail Using Outlook 1
M Microsoft 365 Outlook keeps requesting password on Local Account Using Outlook 1
