Error Codes 0x800CCC79 and 0x800CCC92__
mwesterhof
I'm trying to set up a second email account with outlook express and keep getting these error codes. How do I fix this problem or what needs to be done to Fix them.
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address wasXXXX. Subject 'are you there yet?', Account: 'pop.XXXX, Protocol: SMTP, Server Response: '554 5.7.1 <XXXXRelay access denied', Port: 465, Secure(SSL): No, Server Error: 554, Error Number: 0x800CCC79
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.XXXX, Server: 'pop.XXXX, Protocol: POP3, Server Response: '-ERR Authentication failed.', Port: 110, Secure(SSL): No, Server Error: 0x800CCC90, Error Number: 0x800CCC92
H
Hal Hostetler - Print-Imaging [MVP]
Using port 465 almost always requires an SSL/TSL connection and you have that turned off. The error indicates improper authentication, which would happen when attempting to make an unencrypted connection to an SSL port. Who is your ISP?Hal
