Outlook takes 3 minutes to load.
rkanenchen
I just installed Windows 7 to my pc, HP Paviliion a611. Outlook now takes about 3 minutes to load, where unde Windows Vista, it was about 3 to 5 seconds, depending on the number of incoming e-mails. Can someone help me? I am not an accomplished PC owner and need things explained in fairly simple terms.
R How many seconds usually takes an email to get to an outlook account? Using Outlook 0
B Synchronizing files in outlook takes forever Using Outlook 2
B Trying to restore data in Outlook and I get an error message to update the profile but when I click OK it takes me right out Using Outlook 7
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
D Outlook Address Book Using Outlook 0
V Outlook 2016 Does Outlook-2016 (64 bit) work with iCloud for Windows ? Using Outlook 4
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 2
K Imap PC Outlook + Android phone Using Outlook 1
C All Gmails don't show in Outlook 2019 Using Outlook 3
witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 5
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
J How do I disable advertising in Outlook 2019? Using Outlook 13
B Outlook Calendar not coming down from cloud Using Outlook 2
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 0
