Mail icon in control panel is missing
V
Val_in_CT1210
trying to set up user email exchange account (over the phone) and control panel does not have this icon.
MS site:
To resolve this issue, follow these steps:
Make sure that the following Control Panel file exists and that it works as expected:
<var>Drive</var>:\PROGRA~1\COMMON~1\System\MSMAPI\1033\mlcfg32.cpl
Click Start, click Run, type regedit, and then click OK. Locate the following registry subkey:
HKEY_CURRENT_USER\Control Panel\MMCPL
MMCPL is not an option
V
Val_in_CT1210
Error msg:
Windows cannot find MLCFG32.CPL. Make sure you type the name correctly, and then try again.....
E
Ezil Vinoth
Search and copy 'mlcfg32.cpl' file from another computer and take it in an external drive and paste the file in the locations mentioned below on this computer in which mail icon is missing.
C:\Program Files\Microsoft Office\Office12\1033
C:\Program Files\Common Files\System\MSMAPI\1033
Now check if you can find the mail icon.
J Control Panel Mail (settings) icon missing Using Outlook 2
M Floating Delete Icon in mail list Using Outlook 1
D How do I get a new mail icon into my quick launch bar? Using Outlook 3
C New mail icon on taskbar intermittent Using Outlook 1
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
MrMayor SENT mail not reloading to top?? Using Outlook 4
ThinkToday Calculate reply time of outlook mail Using Outlook 1
B Outlook 2010 Opening Mail Attachment Using Outlook 2
D Mail in Sent Items Gone Using Outlook 12
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
S Outlook not receiving mail Using Outlook 1
oliv- How to distinguish whether mail is incoming or outgoing? Outlook VBA and Custom Forms 2
W Receiving mail for account that has been deleted Using Outlook 2
O How to prevent CC from showing when creating a new mail? Using Outlook 1
I Junk Mail and PersonMetadata Using Outlook 2
T 3 months of archived e-mail is missing Using Outlook 1
B Outlook - Mail from safe senders list being sent to Spam Folder Using Outlook 0
G Detect Google Drive and OneDrive links in incoming mail Outlook VBA and Custom Forms 3
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
D after delete mail, open the next one Outlook VBA and Custom Forms 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
B Clear Offline Items (Mail Folder) via VBA Outlook VBA and Custom Forms 1
M Moving mail to another folder is much slower than before (Office365) Using Outlook 0
M Sent mail not showing in my sent folder Using Outlook 9
CWM030 Connected accounts mail moved to trash? Exchange Server Administration 16
N Tracking Mail items being moved to folders Outlook VBA and Custom Forms 5
