add address from outlook 2007 contacts to word document problem
BCY123
I am unable to add outlook 2007 contact address to a 2007 word doc. I know about adding the addressbook icon to the QAT but when i use that it only adds the name of the contact, not the address...any help is appreciated
BCY
G
Gordon B-P
Does this happen with all contacts or just one?
If you find my response helpful, please click on the " Vote as Helpful" button!Thank you!
BCY123
seems to be all contacts....i can see all my outlook contacts....but when i choose one...only the first and last name appear in the word doc
thanks
BCY123
thanks for the response russ ...i checked out the link...but that is way too much ... i am very good with code, but do i really need to do all this to get the adressbook QAT trick to work??
thanks
Russ Valentine
Yes. Read the instructions. They are very simple.Russ Valentine
G
Gordon B-P
This is a Word issue, not Outlook. You need to modify the AddressLayout Autotext entry. Read instructions here:http://www.gmayor.com/Macrobutton.htmRuss Valentine
Russ,
Any idea what would cause Word to need that? (Mine just works...)
Russ Valentine
No idea what changed AddressLayout in this instance. The one posted in Graham's article is the usual default for Word, so it should work that way.Russ Valentine
BCY123
Thanks folks...looked at the gmayor site
seems to be relatively easy..is it just open word and hit alt f3, then name it addresslayout?? or do i need to setup and define the autotext?? really not clear to me...if the current command is yielding only the name, why will this small change result in the name + address??
thanks for the help...much appreciated
Byron
BCY123
OK getting closer!! i took the text from the gmayor site created the addresslayout autotext and all seemed good...but when i use the button on the QAT..same thing..just name. so i went into autotext and found the new entry and hit insert and now i get the actual text in the entry
{<PR_GIVEN_NAME> <PR_SURNAME>
}{<PR_COMPANY_NAME>
}{<PR_POSTAL_ADDRESS>}
weird
so 1. i need to get the insert to work right and 2. i also need to re define the button on the QAT to run the new entry...is that correct... BTW interesting problem....
thanks
byron
BCY123
been fiddling with this...so the situation is that i can use the PR commands to insert name, ph#, company but anything related to the address does not insert
so PR_Postal_code or PR_Postal_Address....just give blank lines....
any thoughts
Byron
BCY123
OK
got it....some addresses work OK..others just insert the name, i do not know why...they all seem fine, but i have been using Outlook for years back to the 90's so perhaps the older contacts did not import properly???
anyway to fix this??
byron
Russ Valentine
If you've ever imported Contacts there is a very good chance they didn't import properly. That's why you never use import to transfer Outlook data. Just copy the Outlook data file and open it to transfer data.Russ Valentine
Tech Checkers Make Outlook add Contact Card Address in Location Field based on Appointment Subject Name. Using Outlook 2
M unsuccessful attempts to add new email address to existing Outlook account Using Outlook 2
D Unable to add email address to contact Using Outlook 3
K add an email to an account without linking and tracking the email address BCM (Business Contact Manager) 0
V Add Additional MAPI address book GPO? Using Outlook 12
W how to add ...person wrote...email address..reply Outlook VBA and Custom Forms 3
N Right-click an address -&gt; add to BCM? [OL2007] BCM (Business Contact Manager) 1
M Add-in for verfying recipients email address is in the attachment Outlook VBA and Custom Forms 1
B Task Filter Not Working When I add too many criteria Using Outlook 0
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
B Searching for a Add-In Using Outlook 3
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
