Outlook will not open pst backup from Mozy
MoreIce
Reinstalled xp and Outlook 2000 after a crash. I've downloaded the Outlook pst file from my online backup provider Mozy. I've been successful importing the pst archive file but cannot import the pst file with more recent information. I have also tried to unzip the downloaded pst file directly to the Outlook Local Settings with no luck.
Russ Valentine
You do not import PST files. You open them using these steps: File > Open > Outlook data file. State what happens when you try to access the file correctly. State the format and properties of this file.
Do not ever place a backup file in Outlook's default location. You will very likely overwrite another PST file and corrupt the Outlook profile or even the file itself.
Russ Valentine
J Outlook won't open. PST file busy. Using Outlook 3
L Trying to open contacts pst. file in outlook 365 Using Outlook 3
P open reminders missing after copying outlook pst file Using Outlook 2
M Disk Reads of outlook.pst while outlook not open Exchange Server Administration 1
M Mistakenly Linked my Outlook.pst file extension to open with Outlook Using Outlook 1
P cannot open default email folders errors in c:\users\officemax\appdata\local\microsoft\outlook\outlook.pst Using Outlook 1
V Outlook will not open... Says Outlook2.pst is not a personal folder file Using Outlook 9
G Cannot open, add, connect to PST files from Outlook Pro Plus 2010 RTM Using Outlook 12
witzker Open Contact missing in Outlook 2019 Using Outlook 2
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
C Can't Open Outlook 365 Using Outlook 0
M outlook won't open! Using Outlook 1
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
N open the hyperlink in Outlook directly instead of browser Using Outlook 1
A open Outlook with multiple windows. Using Outlook 0
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item New Slipstick.com Articles 0
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open New Slipstick.com Articles 0
Diane Poremsky Outlook Links Won't Open In Windows 10 New Slipstick.com Articles 1
L Outlook 2013 won't open MS Office attachments Using Outlook 1
Diane Poremsky Open Shared Mailboxes in Outlook on the Web New Slipstick.com Articles 0
V Cannot start Outlook. Cannot open the Outlook window. Using Outlook 8
Z Outlook 2007, clicking email addresses fails to open Contact Using Outlook 0
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
M Cannot start MS Office Outlook Cannot open the Outlook window Using Outlook 2
Gareth Outlook Task Will not open. Using Outlook 5
D Outlook VBA to open Excel attachment and send recipient's email address to a workbook cell? Using Outlook 4
M Can't open same msg file more than once at the same time in Outlook 2010 Using Outlook 7
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
F Cannot open extracted .msg files from outlook Outlook VBA and Custom Forms 1
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
L Outlook 2007 Open Folder From a Contact Using Outlook 22
B Add-in "always enabled" but Outlook 13 won't open Using Outlook 7
L Outlook 2007 Macro Open Contact Folder Using Outlook 7
Lucas attachments in outlook don't open, when Icloud is connected Using Outlook 0
T Outlook 2010 Very Slow To Open Recently Using Outlook 9
W outlook refuses to open any attachments ... not related to shadow directory Using Outlook 2
M Outlook hidden even when open (maximising doesn't fix it) Using Outlook 2
