Auto Archive function missing from Outlook 2007
P
PC Bevo
I went to adjust my auto archive settings today only to find that the auto archive function is missing. Has anyone else experienced this problem and is there a way to reactivate auto archive?
P
PC Bevo
Thanks for the help. I deleted the update and the auto archive was returned to normal, as was the speed in viewing folders. Thanks again.
P
PC Bevo
No, I haven't installed the new update, though I will probably do that sometime today. It's on my wife's computer and she's happy that everything is working better after I deleted the update that had problems.
Ben M. Schorr [MVP]
Please do let me know how it goes after you do install it. Thanks!
B Outlook 2016 Auto-archive creates new folder Using Outlook 4
J Auto-archive with Exchange account Using Outlook 2
R Outlook 7 auto-archive Using Outlook 1
E Auto archive does not exist in my outlook 2007. Using Outlook 2
M MS Outlook 2007 - Auto Archive feature removed after MS update Using Outlook 1
J missing auto-archive control in outlook 2007 Using Outlook 8
J Online Archive / Auto Archive functionality Exchange Server Administration 3
D Error during auto-archive in Outlook 2007 Using Outlook 1
D Archive cannot be opened during auto-archive Using Outlook 1
J how to auto-archive exchange mailbox to local mailbox Using Outlook 1
C Outlook 2010 will not archive auto or manual Using Outlook 1
D Can you Auto Archive a Mailbox that is not your main Mailbox? Using Outlook 2
J Auto-Archive Outlook 2003 Using Outlook 2
J How to recover calendar after auto archive deleted it. Using Outlook 6
R when moving mails from my mailbox's inbox folder to archive folder or personal folder mails are auto Using Outlook 3
P [SOLVED] Auto remove [EXTERNAL] from subject Using Outlook 6
