Email stuck in Outbox and tries to keep sending.
C
casbuilder
A few weeks ago, I sent out five emails that contained large zip folders. Two of the five went through, but the last three won't. They keep trying to send and are causing my outlook to stop responding. I no longer need to send these emails and can't delete them. How could I get these to stop trying?
N
Niranjan I K
Try the following steps to resolve the issue.
Click File > enable "Work Offline" and then remove the stuck emails from outbox.
Once the emails are removed from the outbox, disable "Work Offline".
P OL 2007 XP email stuck in outbox Using Outlook 3
D Email stuck in Outbox Using Outlook 3
G Email stuck in Outbox - Office 2013 Using Outlook 5
N Email Stuck in Outbox - Cached Mode - Roaming Profile Using Outlook 2
D Windows 7 / Outlook 2007 - email gets stuck in Outbox Using Outlook 2
S outbox is stuck sending an email. Using Outlook 1
A An email is stuck in my outbox Using Outlook 2
M Distribution lists not working, outlook will not open properly and email stuck in outbox. Using Outlook 3
C Email stuck on outbox and will not send. Using Outlook 3
D Email message gets stuck in Outlook 2007 Outbox Using Outlook 5
S email stuck in outbox and sends repeatedly Using Outlook 9
S I am not able to delete an email stuck in my outbox. All of the various delete actions have been tried without success. Using Outlook 2
J email is stuck in outbox Using Outlook 2
S Having trouble with email stuck in outbox Using Outlook 1
C Deleting stuck email from Outlook 2007 outbox Using Outlook 1
C Email stuck on outbox Using Outlook 1
J video email stuck in outbox Using Outlook 1
C Tried to send an email with attachments that were too large and not it is 'stuck' in my outbox. Using Outlook 1
W email stuck in outbox Using Outlook 6
H Email stuck in Outbox and cannot delete it. Using Outlook 3
T how do I delete email from outbox...they are stuck Using Outlook 1
M deleting an unsent email that is stuck in the outbox Using Outlook 0
P Email is getting stuck on outbox in outlook 2010. Using Outlook 1
3 email with photos is stuck in outbox Using Outlook 1
M large emails stuck in outbox, receiver keeps getting the same email Using Outlook 1
K Outlook 2007: email sporadically stuck in outbox Using Outlook 4
M I have an email with photo attachment stuck in Outbox. When I try to delete it says, "THis item coul Using Outlook 2
R Outlook 2003 Email stuck in Outbox when using a non-admin ID Using Outlook 6
T Add-in problem: First email in outbox gets stuck Outlook VBA and Custom Forms 7
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
A email stuck on send Using Outlook 3
M Outlook 2003, email stuck in send mode, cannot delete Using Outlook 1
S 35MB email stuck in Outlook 2003 Using Outlook 4
C I have an email stuck in my outlook out box and the system will not let me delete it. How do I remove it? Using Outlook 1
D Sending email from Office 365 alias in Outlook Using Outlook 4
S Macro or plug-in to see if specific person was included in this email Outlook VBA and Custom Forms 2
S Body text of Email from invite date/time Outlook VBA and Custom Forms 8
R Outlook 2010 How do you export 2 email Accounts' 2010 Inbox Files to new computer (2019)? Using Outlook 1
L Outlook saved email templates Using Outlook 1
