Delivery delay set by default
StuartDDonaldson
Outlook 2007 has just started adding a delivery delay to sent emails.
There are no rules set to do this.
emails sit in the Outbox with delivery set to none and line characters in bold but not italic.
If email is re-opened and then re-sent the same thing occurs except line is no longer in bold.
If a rule is added to set delivery delay to 1 minute, when the time has passed the email is still not sent.
If delivery delay is manually unticked before 1st sending it makes no difference. When the email is re-opened and Delivery Options selected the delay check box is re-ticked.
I have uninstalled and re-installed Office 2007.
Help!!
Stuart
Brian Tillman
This is often caused by an add-in. It is not a delayed delivery setting. Start Outlook once in safe mode (hold Ctrl while you start it) and see if the behavior changes. If so, start Outlook normally, use the Trust Center to disable your add-ins, then add them back in one at a time until you find the culprit. Also, make sure that you do NOT scan mail with your antivirus program. Uninstall it completely, then reinstall it with a custom install, leaving out the mail scanning feature. You will be just as safe and the AV program won't be able to interfere with your mail.
N
Niyamath Khan
What type of email account was configured in Outlook? E.g. POP/IMAP/Exchange
You may start Outlook in safe mode and then try to send emails to check if it helps.
Click on Start > Run > Outlook /safe and hit on Enter.
Note: There is space between Outlook and /
J Diane's Delay Delivery at Specific Times Questions Outlook VBA and Custom Forms 5
T Query About "Delay Delivery" Function Using Outlook 5
S Delay Delivery Macro Outlook VBA and Custom Forms 1
Diane Poremsky Delay Delivery of Messages Sent at Specific Times New Slipstick.com Articles 0
G "Delay Delivery" Email fails to send if opened while in Outbox Using Outlook 4
D Delay Delivery: Visible to recipients? Using Outlook 1
K Outlook 2007 Delay Delivery feature not working Using Outlook 1
P Delay delivery not working in Outlook Using Outlook 1
H Delay Delivery Option is being automatically selected and cannot be changed and does not allow emails to be sent. Using Outlook 1
J Rule to Forward email but delay delivery 10 minutes Outlook VBA and Custom Forms 2
C Outlook 2007 Delay Delivery Problem Using Outlook 10
M cannot change delivery folders with IMAP accounts Using Outlook 0
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
M Delivery receipt for MYOB emails Using Outlook 0
M Why delivery receipt size is same than sent email size or even larger? Using Outlook 1
P Mail delivery failed returning message to sender Using Outlook 1
C Defer email delivery - but when force sent using F9 Using Outlook 1
Z Mail delivery location - I think Using Outlook 1
R Difference between delivery receipts and read receipts__ Using Outlook 2
S Delivery Status Notification (Failure) Using Outlook 3
F Mail Delivery Errors sending to any Hotmail account recipients.__ Using Outlook 2
C Exchange 2010 Mail flow Local Delivery Exchange Server Administration 3
I Cannot view delivery reports. Exchange Server Administration 2
D Exchange 2003 to Exchange 2010 mail stuck in Exchange 2003 Local Delivery Queue Exchange Server Administration 10
P How do I send a 'delivery receipt' notice to sender after rejecting it? Using Outlook 2
P Delayed Delivery does not work after computer re-boot Using Outlook 1
P Delivery receipt with original message attached? Exchange Server Administration 2
M Outlook 2007 default delivery location changes - 2 accounts Using Outlook 2
J Security Update for Microsoft Office Word 2007 (KB2344993) causing IMCEAMAILTO delivery failures. Using Outlook 1
S Delivery Failure - Help! Using Outlook 3
T Remote delivery Exchange Server Administration 1
L Transport Service Issues Message Queue keeps going offline slow mail delivery Exchange Server Administration 1
J How to temporarily suspend mail delivery to one of two mail accounts Using Outlook 1
A Delivery was refused. Code 5.2.1 Using Outlook 6
B MDaemon rejects with 'Permanet Delivery Failure' Using Outlook 1
T Problems with E-mail adresses in Brazil (Mail Delivery Subsystem) Using Outlook 1
A Outlook 2010 Defer Delivery Not Working Using Outlook 1
T I am getting delayed and failed delivery notices for messages to every day contacts. It is causing some problems. Thanks Using Outlook 2
O Delivery and Read receipts in Outlook 2010 Using Outlook 2
L Delivery Failure Using Outlook 1
W When users try to setup a meeting in outlook 2007 or 2003 they will get an Undeliverable delivery st Using Outlook 1
T Mail Delivery Slow to Exchange 2010 Mailboxes (Co-existence with Exchange 2003) Exchange Server Administration 11
S Weird delivery issue Exchange Server Administration 3
V Delivery option missing Using Outlook 7
R message delivery restrictions Exchange Server Administration 3
M Exchange 2007 mail delivery fails to recipients on the Exchange Global mail list Using Outlook 4
A Why don't I see delivery receipts in Outllok 2007? Using Outlook 6
S Microsoft Office Outlook 2010 Quick rule managent with a PST file as the default mail delivery locat Using Outlook 1
R Delayed delivery/receipt of Outlook 2010 messages Using Outlook 1
