Microsoft has encountered a problem and needs to close.
W
wmcarthur
Every other Email or reply from an email or a new email will cause this. once the address is entered the error message will appear and it will completely restart after you click "Don't send".
Ideas:
Outlook 2010 Programs you are having problems with error signature; appname:eek:utlook.exe appver: 14.0.4760.1000 appstamp:4ba8fefd modname: outlookaddin.dll modver:6.0.9330.1557 modstamp: 4a4a20c0 fdebug:eek: offset:00031a26 Error messagesjust updated to office 2010 Recent changes you made to your computer ran repair within office 2010, uninstalled and reinstalled, loaded all updates. What you have already tried to fix the problem
H
Hassan El-Meligy, MSc
Did you try running outlook in safe mode and see if it does the same problemsDid you try checking upon the ADDINS you have Could you disable the ADDINS one by one and trace which one (might) causes problems
Let me know which one might be of help
Best Regards
Roady [MVP]
Do you have a Dell computer? They install an add-in with that name as well (by Cyberlink). Uninstall this add-in and try again.
If you don't have this add-in installed, it could also be caused by other software considering "outlookaddin.dll" is a very generic name but it is definitely 3rd party.
To troubleshoot your add-ins see;
http://www.msoutlook.info/question/88
J Microsoft Office Outlook has encountered a problem and needs to close. We are sorry for the inconve Using Outlook 2
K Microsoft office outlook has encountered a problem and needs to close. We are sorry for the inconven Using Outlook 3
J Microsoft has encountered an error....Outlook must shutdown. Using Outlook 1
D "Microsoft Outlook has encountered a problem and needs to close. We are sorry for the inconvenience. Using Outlook 3
J Microsoft Outlook has encountered a problem and needs to close Using Outlook 8
K Microsoft Office Outlook has encountered a problem and needs to close. Using Outlook 3
J Outlook 2003 error-Microsoft outlook has encountered a problem Using Outlook 111
tswatek Microsoft Outlook has stopped working Using Outlook 13
padubajacket Microsoft Outlook has stopped working Using Outlook 2
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
J Microsoft Outlook Calendar - end time of appointment has started printing but don't want it to print Using Outlook 2
J Microsoft Outlook has stoped working Using Outlook 2
G Microsoft Outlook 2007 may experience Send/Receive or performance issues after a recent update (KB2412171) has been installed on the computer Using Outlook 2
S Connection to the Microsoft Exchange Server has been lost. Outlook will restore the connection when Using Outlook 2
T error message: microsoft office has stopped working Using Outlook 2
V Your Mailbox Has Been Temporarily Moved On Microsoft Exchange Server____ Using Outlook 1
T I have Office Professional 2010 and Microsoft Outlook has stopped working Close the Program__ Using Outlook 2
V Your Mailbox Has Been Temporarily Moved On Microsoft Exchange Server__ Using Outlook 7
C connection to microsoft exchange has been restored Exchange Server Administration 3
E My Microsoft Office 2010 Beta version has expired. How do I backup my Outlook contacts and email bef Using Outlook 1
T "Microsoft Outlook has stopped working" error message in Office 2010 Trial Using Outlook 6
N Connection to Microsoft Exchange has been lost. Outlook will restore the connection when possible Using Outlook 15
B Microsoft Visual C++ Runtime Library message, "This application has requested the Runtime to termina Using Outlook 1
S MICROSOFT OFFICE OUTLOOK HAS STOPPED WORKING. Error: A problem caused the program to stop working co Using Outlook 2
I Microsoft Office Outlook has stopped working Using Outlook 3
S Microsoft Outlook has stopped working Using Outlook 1
S Microsoft Outlook has stopped working. Using Outlook 2
S Microsoft Outlook has stopped working. Using Outlook 1
C No error code. Message 'Microsoft Office Outlook has stopped working. Using Outlook 2
1 Microsoft office has stopped working Using Outlook 2
S "Microsoft Outlook 2010 has stopped working", then something about how it is searching for a solutio Using Outlook 2
M "Microsoft Outlook has stopped working" every time I hit REPLY or REPLY ALL in 2010 Using Outlook 2
G Re: Microsoft Outlook has Stopped Working - Windows can check online or Stop the Program Using Outlook 3
Y MicroSoft Office Outlook 2003 error message! Your IMAP server has closed the connection. This may oc Using Outlook 2
P Microsoft Outlook has suddenly stopped working Using Outlook 2
R Microsoft Outlook has stopped working Using Outlook 10
J MicroSoft Office Outlook 2003 error message! Your IMAP server has closed the connection. This may Using Outlook 2
P The Microsoft Exchange Administrator has made a change that requires you quit and restart Outlook Exchange Server Administration 7
B microsoft outlook out box has had 4 messages in to be sent for 2 weeks other messages are sent not these4 .windows vista microsoft 2007 .I cannot dele Using Outlook 1
W Microsoft Office 2003 w/ AOL folder problem: Your imp server has closed the connection. Can’t move Using Outlook 7
B Microsoft Outlook has stopped working (Office 2010) Using Outlook 15
M HELP! Microsoft Outlook 2003 has stopped working - what to do? Happens every time I open it. Just started happening today. Using Outlook 2
D Microsoft.Exchange.Search.ExSearch.exe has CPU pinned for 8 hours Exchange Server Administration 6
C Message reads 'Microsoft Outlook has stopped working, in blue. In black the statement 'A problem cau Using Outlook 6
B Cannot open your default e-mail folders. The attempt to log on to Microsoft Exchange has failed. Exchange Server Administration 10
D microsoft outlook has stopped working, close program, windows will check for solution Using Outlook 9
T Microsoft OUtlook has stopped working BCM (Business Contact Manager) 1
R "Your mailbox has been temporarily moved on Microsoft Exchange Server" Using Outlook 7
M Microsoft 365 Outlook keeps requesting password on Local Account Using Outlook 1
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Calendar Printing Assistant 3
