outlook 2010 not responding
bosty35
Outlook opens fine but hangs up when recieveing and then int eh title bar displays not responding
bosty35
found teh answer in antoher forum here it is
Try the steps mentioned below:
1. Click Start->Run (Windows key + R key) and type Outlook /safe->click ok.
2. Try to work with the mails and check if it works.
3. If Outlook safe works disable add-ins by clicking on File->Options->Add-ins.
4. Click go for COM-add-ins and clear the check box for all the add-ins.
5. Close and open Outlook.
worked well
