Office 2000 problems (I know...it's past time to upgrade...just need to get by a little longer if possible)
L
LauraBellGreeno
Unable to download content from a second IMAP inbox (can't open inbox mail); No connection problems with host server or DSL.primary inbox has been auto-deleting multiple email (if I delete one email message, 2 get deleted);relentless multiple requests for password (even though I always check the "remember my password box").
K
Kathleen Orland [MVP]
This is typical of such an old version of Outlook installed on a newer operating system. Vista does not support Outlook 2002 or older.
Check the size of your Outlook.PST to see if it's at the maximum size (2 GB or even under).
Try configuring your Outlook accounts as Workgroup to see if that helps.
Microsoft
J missing address book in office 2010 after upgrading from office 2000 Using Outlook 3
L Exchange Server?, and Platform Updates For OUTLOOK, part of OFFICE 2000 Professional! Using Outlook 1
G Microsoft office 2000 SR-1 .msi error Using Outlook 9
C Outlook fails to open old .pst files created under Office 2000 Using Outlook 1
A Office 2000 (Outlook error) Using Outlook 1
M Office 2000 - try to open, opens for about 15 seconds then closes Using Outlook 1
J Sending Mail Using Pop3 gmail (Microsoft Office 2000) Using Outlook 2
D Sending email from Office 365 alias in Outlook Using Outlook 4
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
L Can signatures synch to Office Portal Using Outlook 1
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
Jennifer Murphy Outlook can't connect to Office 365 at resort hotel Using Outlook.com accounts in Outlook 1
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
J Migrate from godaddy 365 to office 365 home Using Outlook 8
Microfiche Migration from Office 2016 H&B to Office 365 Using Outlook 0
R How Can I backup office 365 account? Exchange Server Administration 1
O Office 365 Outlook - mark to download Using Outlook 0
T O365 and Office Message Encryption Exchange Server Administration 2
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
L Office 365 cloud based rules Using Outlook 1
T Office 2013 no longer updating automatically Using Outlook 2
O Office 365 - Outlook - Password protect your mailbox Using Outlook 7
Horsepower Office Outlook 365 home opens slower than a month ago Using Outlook 8
J Office 365 - Online Repair vs. Uninstall Reinstall Using Outlook 1
O Backup Office settings - registry key Using Outlook 5
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
J Out of Office, Delegate Using Outlook 1
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
e_a_g_l_e_p_i Just had to reinstall window 10 then Office and forgot how to control fonts sizes Using Outlook 3
B Search function in Office 365 has stopped working Using Outlook 3
L Outlook Office 365 cached mode crashing Using Outlook 0
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
