Not able to send mails through MS Outlook 2007
Deepak Kishwar
For the last two days, I'm not able to send mails on and off using gmail POP3 access using MS Outlook 2007. I'm geeting the message
Undeliverable - Subject Caption
System Administrator
Your message did not reach some or all of the intended recipients.
Subject: FW: Revised Tender Document
Sent: 18-11-2010 21:20
The following recipient(s) cannot be reached:
xxxx@xx.com on 18-11-2010 21:20
None of your e-mail accounts could send to this recipient.
The mail is moved from outbox to sent box in split second no matter how big is the attachment and instantly this meessage is received in inbox
I'm able to receive mails on both my gmail & rediffmail POP3 account
Please provide some help
Deepak Kishwar
I have re-checked the Account setting and everything is fine and was able to send test mail.
Though during the Process i noticed one thing that if I select a senders address from the contact list then only i get this message, whereas if retype the same sender address again, mail works fine.
This i have checked with several address in my contact list and its the same thing with every contact tested. I have not made any change to contact list recently and these recepeints are very old and i keep on sending mails to them very frequently by picking the address from contact list ony.
Only one change in recent past has been made that i have changed my Windows Smart Phone to Android Smart Phone which was synchronised with the system and checking mails both on my PC as well as Phone.
Hope you would be able to provide me some help,
Thanx.
G
Guruprasad Ra
Try to manually type the email address in the "To" field and verify if it delivers the email correctly. If the message gets delivered, you may need to rebuild the contacts in Outlook
G Not able to send ANY emails due to a blocked list Using Outlook 2
S Suddenly I am not able to send e-mail but can receive. We use Windows7 and Outlook has been working for about a year. Using Outlook 2
D I am able to send emails on Outlook, but unable to retrieve emails trying to come in. Using Outlook 1
B Switching Access from version 2010 to 2007 or 2003 causes Outlook to no longer be able to send or receive email. Using Outlook 2
S Unable to send emails through outlook, but able to recieve emails Using Outlook 2
D I am not able to send emails from outlook 2003 Using Outlook 2
S Without Authentication able to send and receive email via POP3 - With Authentication not able to Send Exchange Server Administration 4
N I am not able to send emails in 2003 and emails are stuck in the outbox. Also must manually click b Using Outlook 1
C Not able to send emails with Outlook 2007 using Vista BCM (Business Contact Manager) 1
N BCM suddenly crashed and not able to view specific business contact. Using Outlook 1
Fozzie Bear Wishlist To be able to add a local folder or network share location in foldern view Outlook Wishlist 1
L Outlook 2010- Be able to move default Mail folders (Outbox, Draft, etc) Outlook Wishlist 1
P Not able to receive meeting request Using Outlook 2
D No longer able to Archive Outlook 2007 Using Outlook 1
N Not able to receive daily emails. Using Outlook 3
S I'm not able to copy and paste on outlook. Using Outlook 1
T Have to type in login to OWA twice before able to login Using Outlook 17
M Outlook Anywhere is not showing freebusy informayion and User not able to open shared calender while Using Outlook 1
R No problems for about three months and the, about two weeks ago I was no longer able to receive emails in Outlook. Using Outlook 4
D Not able to retrieve my emails or get to my contacts using outlook. Using Outlook 3
K Sending email in Outlook - being able to choose... Using Outlook 1
E 554 message not allowed [320] I am able to receive emails from these contacts but when i reply i get this error code. It is from contacts that i have Using Outlook 1
G Not able to accept meeting with outlook 2010 Using Outlook 0
J DAG problem - I´m not able to recover database Exchange Server Administration 9
G Not able to accept meeting with outlook 2010 Using Outlook 1
A error 2147504141 -I am not able to fix this error even after attepmting all IPv6 related sloution. Exchange Server Administration 3
A Not able to search by last name in GAL Exchange Server Administration 3
S Not able to establish Outlook on Windows server, office email, yahoo account Using Outlook 1
D I would like to be able to Forward a Template to a specified email address on receiving an email in the Inbox. Using Outlook 1
H Not able to get messages forwarded from my road runner account. Using Outlook 2
S How do I set up more than 1 email account for Outlook 2007. Have recently purchased a laptop and want to be able to check all emails that come into t Using Outlook 2
M Not able to select my contacts list for my address book Using Outlook 7
M Need to copy old PST file from CD into Outlook so as to be able to open and view the old documents. Using Outlook 7
A SCOM 2007 R2 not able to see Exchange 2010 mailbox server Exchange Server Administration 4
S Not able to open webmail inbox. Using Outlook 2
S Me and my big mouth...I said to my customer a district nursing organization down here in New Zealand, that 2 ipaqs should be able to share the same Co Using Outlook 1
T Need to be able to check my microsoft outlook emails via my blackberry Using Outlook 1
O owa was not able to process this request Using Outlook 3
M not able to recieve Internal and external email on a 2010 mailbox... attempting exch 2003 transition Exchange Server Administration 2
L I was able to password protect attachments in my earlier version of Outlook, but can't figure out ho Using Outlook 1
A not able to find Contacts when writing new email, even clicked the Searh Name button.__Try to set the address list or book, but nothing listed in the Using Outlook 1
L not able to access signatures to modify, add, or edit. Using Outlook 1
N Not able to select the details of a head office synced contact Exchange Server Administration 4
J Add a meeting / appointment to my Calendar without emailing the other person (like I was able to do Using Outlook 3
G SP1 upgrade fails in Install-MailboxRole due to not being able to resolve Discovery Management group Exchange Server Administration 28
A not able to change password by EX2010 OWA for few user's Exchange Server Administration 26
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
