Junk setting do not respond to "Never Block Sender
Desert Rob
I receive several items in my spam folder and some of the email are not spam. I click on one to select it and then go to the down arrow under " Junk" and click on " Never Black Sender" . This doesn't help, Outlook still considers the email to be spam and continues to direct them to the spam folder. I would like to get them in my inbox. I have also selected one of these non-spam emails and beside doing the " not spam" I move them into my inbox. But nothing works. Outlook still considers them spam. How can I change this selection by Outlook?
Desert Rob
I am using a cable internet provider with Outlook 2010 as my email. There is nothing to indicate that Outlook is moving anything to the junk folder. Some incoming messages are moved directly to the Junk folder without any indication at all even though I have marked them as " Never Block Sender.
C starting Outlook 2003 sp3 sets Junk Email setting to 'No automatic filtering' Using Outlook 3
P Setting Hotmail Junk Mail Settings from Outlook Doesn't Work Using Outlook.com accounts in Outlook 1
F Junk Email does not get added to the Blocked Sender List Using Outlook 1
I Junk Mail and PersonMetadata Using Outlook 2
F Outlook 2016 Junk E-Mails Using Outlook 5
J Junk mail doesn't work Using Outlook 3
T New Account Shows No Junk Mail Folfer Using Outlook 0
T Probem with junk mail folder in new account in Outlook Using Outlook 0
C Why can junk mail be from one’s own email address? Using Outlook 7
M junk mail folder Using Outlook 2
Diane Poremsky Junk Mail Filtering in Outlook New Slipstick.com Articles 0
K Emails stuck in 'Junk' folder Using Outlook 0
David Rahrer Change default Junk E-Mail folder Using Outlook 6
S Outlook.com - Junk files Using Outlook.com accounts in Outlook 1
R Not junk email Using Outlook 3
lotsbg Loads of junk in second email needs fixing Using Outlook 1
7 Macro to mark message as junk and delete Outlook VBA and Custom Forms 3
G filtering email with missing TLD to Junk Outlook VBA and Custom Forms 1
R Outlook - alternatives to Rules / Junk? Using Outlook 5
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
R Outlook 2007 junk mail Using Outlook 4
mrje1 Junk Options - Safe Lists not working. Using Outlook 0
C Outlook 2013 Junk Mail Filters Using Outlook 0
L My junk email folder has disappeared - Using Outlook 0
Commodore Junk Mail filtering and IMAP Using Outlook 3
D Junk Mail filter Using Outlook 1
V Macro to view Junk Email folder Using Outlook 4
J Junk email Exchange Server Administration 1
V Emails going to Junk folder Using Outlook 2
A Junk mail Using Outlook 4
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
U Problems with junk mail folder... Using Outlook 1
R Emails suddenly going to the Junk email folder Exchange Server Administration 3
G Red crossed circle disappeared from Junk Mail folder Using Outlook 3
O Emails still going to Junk Mail Using Outlook 8
D Junk Mail location Using Outlook 1
J Junk email filer stopped working in Outlook 2010 (32 bit) on a 64-bit Win 7 PC Using Outlook 12
E Can rules be applied to the Junk E-mail folder? Using Outlook 2
C Junk Folder not operating Using Outlook 4
D Disable Junk Email in the Registry? Using Outlook 8
R Junk email window automatically minimizes Using Outlook 1
D User behavior influencing Junk mail designation Using Outlook 1
B Outlook 2003 junk mail issue Using Outlook 1
