Error when click on links in Outlook 2010
trcampbell57
This is the error message I get when I try to click on a link in Outlook 2010.
"This operation has been canceled due to restrictions on this computer. Please contact your system administrator."
I have tried many things and I cannot find what is causing this error. I just uninstalled Google Chrome prior to this problem occuring. I am not sure if that had anything to do with this error or not.
BTW – I am using the new IE 9 Beta. I have had other problems where I have to close IE or even reboot entirely to get IE 9 working again. And even worse I can"t even remove IE 9 Beta because it does not show in the programs list. This problem, however, just started yesterday and I installed IE 9 Beta several months ago.
Can someone please help me get this fixed?
V
Vincenzo Di Russo [MVP]
See:
This operation has been cancelled due to restrictions
"This operation has been cancelled due to restrictions in effect on this computer."
"... you may also need to change the HTM/HTML association in the registry.Start, click Run, type Regedit in the Open box, and then click OK. Browse to HKEY_CURRENT_USER\Software\Classes\.html Right click the value for the .html key and select Modify... Change the value from "ChromeHTML" to "htmlfile" (or from FireFoxHTML to htmlfile)
Repeat these steps for htm and .shtml keys if they exist. You may also want to check the xhtml and xhtm keys.
Don't want to edit the registry? Download this file (right click and choose Save target as...) Change the extension to reg and double click to run..."
Cf.:
-> http://www.slipstick.com/problems/link_restrict.htm#reg2
Read also this thread.
Vincenzo Di Russo
Microsoft® MVP Windows Internet Explorer, Windows Desktop Experience & Security since 2003.
Moderator in the Microsoft Answers and TechNet Forums Italy
My MVP Profile: https://mvp.support.microsoft.com/profile/Vincenzo
B When I try to click on links within an e-mail I received, I get this error message: 'This operation has been canceled due to restrictions in effe Using Outlook 1
G When I click on any links in outlook I recieve the error message 'This operation has been cancelled due to restrictions on this computer. Please Using Outlook 1
A I am receiving an error message when I click on links within an email. Using Outlook 0
V Can't click on embedded link in Outlook e-mails--error message "not allowed" Using Outlook 6
B Trying to restore data in Outlook and I get an error message to update the profile but when I click OK it takes me right out Using Outlook 7
M When I click a link in an email I get a error message Using Outlook 2
C CLICK TO FOLLOW LINK GIVES AN ERROR Using Outlook 2
T Hyperlinks in emails give error message when I click on them Using Outlook 2
J When I try to click on a link embedded in an email I get an error that says that computer restrictions prevent access. Call the system administrator Using Outlook 1
V I get an error message when I try to click on any link that is within an email I have received. Using Outlook 1
I Got Error - "can't contact LDAP Directory server" when click on "To" to get email address from my co Using Outlook 2
A This operation has been canceled due to restrictions in effect on this computer' error message when you click a hyperlink in an Office 2010 progr Using Outlook 1
A Error - 'the custom form cannot be opened' when click on any calender invite. Using Outlook 1
B When I click on Send/Receive, Outlook reports error code 0x00000e50 and closes. Using Outlook 17
K 'The Operation Failed' - error message when I click on send mail. Using Outlook 0
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error New Slipstick.com Articles 0
