.pst backup deletion causing problem
C
CedarDog
I have Outlook 2003 runing under Windows7
I created a .pst file to import email contacts to Yahoo email. This file worked well and I had it saved to the desktop, then I deleted it. Now, whenever I open Outlook I get a dialog box labeled PERSONAL FOLDERS that says c:\users\cedar\desktop\backup.pst could not be found. When I select OK, a new dialog box opens CREATE/OPEN PERSONAL FOLDERS and then wants me to create a personal folder with a password. When I look for the original file I get a CANT BE FOUND message. I have gone through many steps to cure this and find no mention of problems in the MS help forums nor have I seen any special instructions for deleting a personal file folder.
How do I get rid of these dialog boxes? It's become annoying.
Russ Valentine
You probably can't. To avoid corrpting your Outlook profile, avoid manipulating Outlook data files in Windows Explorer until you have disconnected them from your Outlook proifle. Create a new Outlook profile if the prompt annoys you.Russ Valentine
D PST file backup Calendar Printing Assistant 1
R Recover/export rules from a backup .PST Using Outlook 2
V Outlook Data File (PST) - Auto Backup Solution Using Outlook 3
V Backup pst to NAS drive? Using Outlook 4
D Outlook 2010 .pst file backup Using Outlook 2
M Outlook will not open pst backup from Mozy Using Outlook 2
R How to backup sub-folders within .pst Using Outlook 5
J Access Denied - Error Applying Attributes to Outlook.pst After Backup Using Outlook 1
S What is a good utility to backup pst files for executives who have laptops. Backup changes only. Using Outlook 1
H PST Disappears - Backup PST disappears - newly generated PST has email from 2 weeks ago - what's happening? Using Outlook 2
B Recover PST from backup - 'you dont have permission to open this file' Using Outlook 3
L Backup pst needed to access calendar Using Outlook 1
T importing backup.pst files by folder name. Using Outlook 2
D cannot import .pst file from a backup .pst (personal folders) file exported from Office 2007 Using Outlook 3
B Backup of Outlook PST files Using Outlook 1
D i try to backup my pst with a third party software who says that the pst is locked.... Using Outlook 2
E IMPORTING OUTLOOK PST BACKUP ERROR 'NOT COMPATIBLE WITH THIS VERSIONOF THE PERSONAL FOLDERS INFORMAT Using Outlook 1
F pst backup Using Outlook 3
J Outlook PST Backup tool Using Outlook 4
D Outlook 2010 .pst backup Using Outlook 4
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 3
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 2
S What's in a PST file? Using Outlook 1
N pst files are recreating automaticaly and cannot be deleted Using Outlook 6
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
N Two .pst files on one computer both with contacts? Using Outlook 9
DariTrevino MIcrosoft Outlook PST file cannot repair Using Outlook 1
E Exporting email (.pst) Using Outlook 8
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
