BCM 2010 Will Not Setup
N
National SS
I loaded all the software and when I open outlook it says BCM caused a serious issue and needs to be disabled. I have never been able to use it on a new install. I uninstalled, un-disabled. I tried evrything. I have never seen the set-up menu for BCM when outlook is opened. I even manually loaded SQL 2008. Sometimes Outlook starts to open then disapears. I click it few more times and there open processes running which I then end and restart.
I have loaded it on my laptop as well and have the same issue of not getting it to recognize.
Jennifer Zhan
Try to disable the BCM via registry.
Click Start, click Run, type regedit, and then click OK.
Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins\Microsoft.BusinessSolutions.eCRM.OutlookAddIn.Connect.1
Right-click LoadBehavior, and then click Modify.
In the Value data box, type 1, and then click OK.
Quit Registry Editor.
If you want to re-enable Business Contact Manager after you have disabled it, follow these steps:
1. Quit Outlook.
2. Click Start, click Run, type regedit, and then click OK.
3. Locate and then click following registry subkey:
4. Right-click LoadBehavior, and then click Modify.
5. In the Value data box, type 3, and then click OK.
6. Quit Registry Editor.
7. Start Outlook.
Hope that helps.
N
National SS
Jennifer,
I tried what you said but my registry does not have that string you mentioned. My string has a different ending.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins\Microsoft.BusinessSolutions.eCRM.OutlookAddIn.NativeConnect.4
I bolded the part that is different. The LoadBehavior value was the same. No I can't even remove the program. It will only allow me to repair. When I ask to remove it does not show any part options to choose for removal.
Any other suggestions?
National SS
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
JimR BCM 2010 or 2013 BCM (Business Contact Manager) 6
J Migration from BCM 2010 to 2013 is messing up the label fields BCM (Business Contact Manager) 4
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
R BCM 2010 Problem with remote office (VPN) users cannot connect BCM (Business Contact Manager) 12
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
R BCM is almost at capacity Outlook 2010 BCM (Business Contact Manager) 2
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
V Permissions in BCM 2010 BCM (Business Contact Manager) 3
M Is there a list of FieldNames that BCM 2010 uses? BCM (Business Contact Manager) 0
A BCM 2010 converts html e-mails to plain text BCM (Business Contact Manager) 1
A BCM 2010 account names import in reverse order BCM (Business Contact Manager) 4
B BCM 2010: Exporting Notes to .CSV with Business Contacts? BCM (Business Contact Manager) 3
J BCM 2010 - New user cannot connect to remote DB BCM (Business Contact Manager) 5
E Can we make custom form as default form in BCM 2010? BCM (Business Contact Manager) 5
N BCM 2010 for CRM tool? BCM (Business Contact Manager) 3
S BCM 2007 to 2010 migration failure issue BCM (Business Contact Manager) 1
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
M BCM 2010 Cannot Connect to Remote Database BCM (Business Contact Manager) 1
M BCM 2010 Link to Record (very) slow BCM (Business Contact Manager) 2
D [SOLVED] Optimizing Outlook 2010 BCM BCM (Business Contact Manager) 2
C Outlook 2010 with BCM - Database Connection problems using Windows 7 Clients Using Outlook 1
T Custom forms BCM 2010; use of form controls Using Outlook 1
S Recovering .sbb file that should be a .bcm file for Business Contact Manager 2010 Using Outlook 3
M Where are contacts stored for BCM 2010? Using Outlook 1
I Outlook 2010 BCM Mass E-mail feature insists on converting outbound HTML emails to plain text Using Outlook 2
I Office 2010 BCM Using Outlook 1
N Receive "Requested Operation Failed" Dialog when trying to add BCM Database in Outlook 2010 Using Outlook 2
B Outlook with BCM 2010 and Windows Mobile will not sync contacts separately Using Outlook 1
P Communication History disappeared in BCM 2010 Using Outlook 22
D BCM for Office 2010 Pro Plus Using Outlook 1
R BCM 2007 to 2010 Conversion fails - Database size > 4GB Help! Using Outlook 1
G Importing BCM file into Business Contact Manager 2010 Using Outlook 3
L 2010 BCM Install Using Outlook 1
K BCM 2010 - Permissions Setting? Using Outlook 1
J outlook and BCM 2010 have Hyper links fileds Using Outlook 3
L BCM 2010 Linking A Business Contact to Multiple Accounts or Projects Using Outlook 1
M BCM 2010 rtm available for registered partners on portal???? Using Outlook 1
M BCM in office 2010 professional? Using Outlook 1
M Does a shared Outlook BCM 2007 database work with both Outlook BCM 2007 and 2010 clients? Using Outlook 2
