Access 64 bit Outlook 2010 from 32 bit C++ application
agr.Vivek
I have a 32 bit application running on a 64 bit Windows 7 machine. On this machine 64 bit Outlook 2010 is installed. My application need to detect Outlook installation and enumerate the Outlook profiles. It then creates a MAPI session and reads/modifies some items such as Calendar etc.
The application used to work fine on 32 bit machines with 32 bit Outlook. However, with 64 bit it is not able to get the profiles as it searches in " HKEY_CURRENT_USER\Software\Wow6432Node\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles" registry keys and profile related keys are in HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles. Please let me know how to access profile related registry keys in a 32 bit app for 64 bit Outlook 2010. Is there any other way apart from registry to enumerate profiles?
Secondly, will MAPI session and other things work from a 32 bit app for 64 bit Outlook? What other issues I can potentially face in my case and what are the best practices around this.
Dave V
First, if you are just reading registry keys and you are a 32 bit application you can disable registry redirection which willl allow you to enumerate the 64 bit registry keys instead of the registry keys in the Wow6432Node. For more information see this MSDN page:
http://msdn.microsoft.com/en-us/library/aa384129(VS.85).aspx
** Please note - The only supported way to manipulate MAPI profiles is via MAPI.
You will not be able to use the MAPI subsystem from a 32 bit application if Outlook 64 bit is installed. This is because a 32 bit application cannot load 64 bit DLLs and vice versa. This is not a restriction of MAPI but of the OS.
" However, 32-bit processes cannot load 64-bit DLLs for execution, and 64-bit processes cannot load 32-bit DLLs for execution"
http://msdn.microsoft.com/en-us/library/aa384249(VS.85).aspx
If you want to use MAPI from your application you will either need to use 32 bit Outlook 2010 or recompile your appliction for 64 bit.
If this post answers your question please mark it as the answer.
C MAPI to access a 64 bit Outlook from a 32 bit application; or access via ODBC Using Outlook 0
Jennifer Murphy Grant R/W (update) access to a friend Using Outlook 3
O The page that you are trying to access cannot be loaded. Using Outlook 0
T Render Outlook emails in MS access as they appear in Outlook Outlook VBA and Custom Forms 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
GregS Can't access archive file Using Outlook 5
R How can I access my emails from corrupt offline files of MS Outlook ? Using Outlook 1
F Outlook 2016 bulk email from access Outlook VBA and Custom Forms 3
J Programmatic access grayed out Using Outlook 10
Diane Poremsky Synchronize Quick Access Toolbar and Ribbons? New Slipstick.com Articles 0
T Cannot access outlook.com accounts in Outlook 2016 Using Outlook 1
B Can't expose sender email address when linking outlook to access Using Outlook 3
Diane Poremsky Change Outlook's Programmatic Access Options New Slipstick.com Articles 0
S how to access the properties of a contact given distlist.member object Outlook VBA and Custom Forms 1
C Merging Word and Access into Outlook Using Outlook 4
I Outlook 2016 and Slow access to Outlook.com IMAP Using Outlook 0
B No permission to access Outlook.pst file Using Outlook 1
M Cannot access the Form Editor BCM (Business Contact Manager) 1
R The changing way to access information in Office 365 New Slipstick.com Articles 0
iwshim Skype tool bar in quick access ribon Using Outlook 1
JorgeDario restrict access to a certain folder with vba Outlook VBA and Custom Forms 3
U Cannot access fields at bottom of Outlook 2013 Contact Rec. Using Outlook 1
S Can't move the items. The item could not be moved. It was either already moved or deleted, or access Using Outlook 3
A Synchronize Access Table with Outlook Calendar Appointments Outlook VBA and Custom Forms 3
R Convert Access table to pst Using Outlook 1
F Get details of sent items with Access VBA Outlook VBA and Custom Forms 1
L Outlook Data Files command not working in the quick access bar Using Outlook 1
T Populating listbox with MS Access table Using Outlook 2
Hudas Hyperlink Saved Outlook Email to MS Access Table Using Outlook 4
