outlook and BCM 2010 have Hyper links fileds
JSoup
The Hyper links fileds in outlook contacts work for internet. But how can I use it to bring up a word document or onenotes page.
The link works when place in IExplorer directly.
it appers that Outlook add to the front of the link HTTP://[url="onenote://E:/My%20Documents/OneNote%20Notebooks/PW&ACC"]onenote:///E:\My%20Documents\OneNote%20Notebooks\PW&ACC[/url] and fails
option on this would be helpfull. thank you in advance Jsoup
Sally Tang
Have you uploaded your documents to the Internet? Can you open the document from the URL link on other computers properly?
You may first upload the document to the Internet successfully.
Best Regards,
Sally Tang
Sally Tang
I am writing to see how everything is going with this issue. Is the problem resolved? If there is anything I can do for you, please feel free to let me know.
Best Regards,
Sally Tang
Sally Tang
As I have not heard from you for several days. I will go ahead and close this thread. If this issue is not resolved or you have any questions, please feel free to reply to us and this thread will be re-opened.
Best Regards,
Sally Tang
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
R BCM is almost at capacity Outlook 2010 BCM (Business Contact Manager) 2
D [SOLVED] Optimizing Outlook 2010 BCM BCM (Business Contact Manager) 2
C Outlook 2010 with BCM - Database Connection problems using Windows 7 Clients Using Outlook 1
I Outlook 2010 BCM Mass E-mail feature insists on converting outbound HTML emails to plain text Using Outlook 2
N Receive "Requested Operation Failed" Dialog when trying to add BCM Database in Outlook 2010 Using Outlook 2
B Outlook with BCM 2010 and Windows Mobile will not sync contacts separately Using Outlook 1
M Does a shared Outlook BCM 2007 database work with both Outlook BCM 2007 and 2010 clients? Using Outlook 2
V Outlook 2010 BCM no longer working after several months of successful use. Using Outlook 11
D Moving from Business Contact Manager for Outlook 2007 to BCM 2010 Using Outlook 1
T Import Outlook 2003 .bcm file into Office 2010 Bus. Cont. Mgr. Error: "Input string was not in a cor Using Outlook 6
S Outlook 2010 Pro Plus official DVDs - BCM will NOT INSTALL it says '64-bit version'!! Using Outlook 4
J Outlook 2010 BCM error message: "The set of folders cannot be opened Store not configured" Using Outlook 7
A Using BCM 2010 mass email - how do you control which outlook email account does the sending? Using Outlook 6
M BCM for Outlook 2010 now on Technet BCM (Business Contact Manager) 2
L Cannot install BCM 2010-"Outlook 2010 Not Installed" but it is! BCM (Business Contact Manager) 1
C BCM for RTM Release of Outlook 2010 BCM (Business Contact Manager) 3
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
K Outlook BCM 2010 and Accounting Professional 2009 BCM (Business Contact Manager) 1
Diane Poremsky Outlook 2016: No BCM New Slipstick.com Articles 0
C Error installing BCM: requires outlook BCM (Business Contact Manager) 25
C Outlook Crashing on Specific BCM Lead File BCM (Business Contact Manager) 2
JimR Outlook 2013 BCM not working BCM (Business Contact Manager) 3
wallisellener Outlook slower after BCM BCM (Business Contact Manager) 1
M Predefined Outlook Fields not available to add into a BCM record BCM (Business Contact Manager) 0
J BCM 2013 in Outlook 2013 will not load BCM (Business Contact Manager) 5
B Outlook 2013 & BCM Issue Using Outlook 2
G Select Outlook account for BCM? BCM (Business Contact Manager) 2
S BCM stops Outlook 2013 BCM (Business Contact Manager) 6
K bcm not showing in outlook 2013 navigation pane BCM (Business Contact Manager) 3
G "database is not compatible with BCM for Outlook 2013" & more BCM (Business Contact Manager) 0
O Other BCM - Outlook sync issues BCM (Business Contact Manager) 1
M Queries on Business Contact Manager (BCM) with Outlook 2013 Using Outlook 1
O BCM 13 added leads to an outlook 13 contact subfolder BCM (Business Contact Manager) 1
V BCM Use with Outlook 2013 BCM (Business Contact Manager) 42
wallisellener Outlook restarting after BCM import BCM (Business Contact Manager) 0
M BCM in Outlook reports maximum database size to 4GB despite SQL Server 2008 R2 BCM (Business Contact Manager) 1
S Help with optimizing Outlook (With BCM and more) Using Outlook 3
