Outlook 2007 addin does not load in other machines
amreen
Hi All,
I have created a Outlook 2007 addin using Visual studio 2010 which has a ribbon visual designer ,
My addin works fine in development machine but in the other machines the addin is not loaded
The load behaviour is changed from 3 to 0 and addin is inactive in Help-->Privacy Options-->Addins
The other machine is
1. Windows xp
2. Office 2007 PIA
3. .Net framework 3.5
4. VSTO 3.0 runtime
I tried to install the Hotfix 976477 but it displays the error as "The expected version of the product was not found on the system".
Im very much in need please do help me
Thanks and Regards
Amreen
H
Harry Yuan
For your issue, I would like to recommend you to post the thread in Outlook for developers forum.
There, your issue will be solved better.
Sincerely,
Harry
