Missing Outlook 2010 Send/Receive button after using Access 2007.
BozoBlippo
I do app development for clients in Access 2003, 2007 and 2010. I have the Office 2010 Pro Plus package installed on Windows 7 Pro x64. I have kept Access 2003 and 2007 and 2010 installed and replaced all other apps with Office 2010 equivalents.
Here's the problem... after switching between Access 2010 and Access 2007, when I open Outlook 2010, the Send/Receive All Folders button on the Outlook Home tab is no longer there (or anywhere else). I have no way to make Outlook retrieve my email. Running Access 2010 to start the switch to the 2010 settings doesn't help. The only solution I've found so far is to do a repair of the Office 2010 install. I can't see doing this indefinately. I sure hope there's a fix.
H
Harry Yuan
From your description , I understand that the send and receive button missed in your Outlook 2010 when your switch between Access 2007 and 2010.
For the Send/Receive button to be available, you must have an e-mail account set up in your Outlook profile.
You may have chosen not to add an e-mail account when you installed Outlook or canceled the New Accounts Wizard.
After you add an e-mail account, the Send/Receive button will be available.
Sincerely,
Harry
BozoBlippo
Hi Harry,
Thanks for the suggestion. The problem isn't with having email accounts. I have three POP accounts and all are set up and work fine. The problem has to do with the conversion activity Office does when one switches between Access 2010 and Access 2007. That conversion process, which happens anytime a user switches versions of Access (and probably any other version switch of Office components) takes about two minutes while the system puts up a message saying it's installing the required components for that version of Office. When I only had Access 2003 and 2007, I could go back and forth, including the conversion process, with no trouble. Now, since installing Office 2010, when I go between Access 2010 and 2007, Outlook 2010's send/receive button disappears. The email accounts are still there... just no Send/Receive button.
Have a sparkling week.
Bob
H
Harry Yuan
Hi, BozoBlippo
It might be caused by corruption in the outlook profile.
Try a new Outlook profile to test the results:
Test with a new Outlook profile
1. Exit Outlook.
2. Go to Start > Control Panel, click or double-click Mail.
3. Click Show Profiles. Choose Prompt for a profile to be used.
4. Click Add.
5. Type a name for the profile, and then click OK.
6. Start Outlook, and choose this new profile.
If this problem does not occur in the new Outlook profile, the old Outlook is corrupted. We can delete that and use a new Outlook profile.
Sincerely,
Harry
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
S Outlook 2010 task - comments missing Outlook VBA and Custom Forms 0
N Outlook 2010 Archived Appointments Missing Using Outlook 5
M Missing New Menu Option in Outlook 2010 Using Outlook 0
W Outlook 2010, missing emails Using Outlook 4
J Outlook 2010 - missing "Updated: ... " in subject text after calendar update Using Outlook 2
S Missing Color Categories Outlook 2007/2010 Using Outlook 2
H Outlook 2010 Advanced Find - Menu items missing Using Outlook 1
M Outlook 2010 subfolders missing Using Outlook 2
C Missing pst file for Outlook 2010 Using Outlook 3
O Outlook 2010 is Missing the security tab - Using Outlook 1
J missing permissions feature in Outlook 2010 (Home and Business) Using Outlook 1
G Outlook 2010 files is not working due to missing .pst files although rest of Office suite is working Using Outlook 4
L how to repair missing send box in a forwarded message in Outlook 2010 Using Outlook 1
G Outlook 2010 - Attachment missing - OWA 2010 Attachment available Using Outlook 3
S outlook 2010 missing features Using Outlook 1
K online archive missing Outlook 2010 Using Outlook 11
M Missing message content in Outlook 2010. Using Outlook 4
J Missing .pst and .pab files after reinstalling Outlook 2010 Using Outlook 2
K Outlook 2010 missing Address Book Using Outlook 3
H outlook 2010: random font changes, missing email content, source html displayed in-line with text Using Outlook 3
B Outlook 2010 missing/losing text in transmission of HTML emails? Using Outlook 11
W Outlook 2010 Favorites missing in navigation pane Using Outlook 12
T Missing Folder in Outlook.com Using Outlook 3
O Outlook 365 - Toolbar - Close all items - missing? Using Outlook 3
S Missing Outlook calendar and contacts Using Outlook 0
T Missing Outlook subordinate folder Using Outlook 0
Diane Poremsky Shortcuts and the Missing Outlook:// Protocol New Slipstick.com Articles 0
O Missing guide "Move an Outlook Personal Folders .pst File" New Slipstick.com Articles 4
A Outlook Postal Addresses Missing/Blank Using Outlook 0
Diane Poremsky Exchange account set-up missing in Outlook 2016 New Slipstick.com Articles 0
M Missing Drafts (Drafts - This Computer Only) Outlook.com Using Outlook 1
F Missing "More Settings" in Outlook 2007 Professional Using Outlook 8
P open reminders missing after copying outlook pst file Using Outlook 2
M Outlook 2013 conversation view ... missing links Using Outlook 3
G Missing outlook 2013 information Using Outlook 2
D folders are missing using imap outlook 2007 Using Outlook 1
W Outlook calendar missing Using Outlook 0
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
K Missing email from Outlook Folders Using Outlook 2
C Form icons are missing in Outlook 2013 supergrid Using Outlook 5
