authentication using outlook 2007 vs 2010
mouhamad
installed:
exchange 2010 sp1
client outlook 2007 send/recieve NO issues..
outllook 2010 recieves no issues
outlook 2010 send issues:
gives me error "unable to relay"
is there a difference in authentication methods between the 2 products?
Jahawk
I came across a previous issue where the users could not send mail from Outlook 2010 via Authenticated relay.
In that case, verbose protocol logging was enabled on the receiving connectors. The log showed 504 Authentication cancelled and 5.7.1 Unable to relay errors.
The resolution for that issue was:
In default and client receive connectors, we unchecked the option under basic authentication, i.e. Offer Basic authentication only after starting TLS.
So, please see if that applies to your situation.
If it does not, please call in and open a Microsoft Support incident with our Exchange Client and Connectivity team. They will be able to assist you with this type of issue.
Jahawk MSFT
mouhamad
partial fix!!
i added the site to "trusted sites" in IE and now it is sending emails. I am getting a certificate error but at least it is sending emails :)
M SSO to OWA from site using Integrated Authentication Exchange Server Administration 5
B Problems using authentication ISAPI Filter with OWA 2010 Exchange Server Administration 4
Commodore iCloud mail with two-factor authentication Using Outlook 7
J Cached mode no longer works with NTLM authentication Exchange Server Administration 0
C Authentication error login rejects Using Outlook.com accounts in Outlook 0
D Constant Dropbox Outlook Addin Authentication Prompts Using Outlook 5
wallisellener Another BCM Authentication thread BCM (Business Contact Manager) 5
S Error after enabling 2-step authentication in Outlook.com/Outlook 2013 Using Outlook.com accounts in Outlook 1
wallisellener BCM authentication BCM (Business Contact Manager) 3
M authentication settings for outlook for mac 2011 Using Outlook 1
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
A Set-OutlookAnywhere Authentication Exchange Server Administration 1
H Another OWA Timeout thread - possible Forms/Basic Authentication with IIS issue Exchange Server Administration 1
D Upgraded to Exchange 2010 SP1 and now random Outlook clients are requesting authentication Exchange Server Administration 1
C SBS 2003 Outlook Anywhere Basic Authentication Issue Using Outlook 2
B error code 0x800CCC80 in Outlook 'None of the authentication methods supported by this client are su Using Outlook 3
D Windows Integrated Authentication with Exchange 2010 Exchange Server Administration 4
E How to set Kerberos Authentication for OWA on Exchange 2010. Using Outlook 2
T How to get Exchange 2003 OWA SSO authentication to work with Internal TMG Array web listener Exchange Server Administration 1
D OWA on 2010 CAS not forwarding authentication to 2003 OWA for legacy users Exchange Server Administration 1
W How to turn off forms based authentication owa 2010 Exchange Server Administration 3
T Autodiscover authentication Exchange Server Administration 2
V GSSAPI authentication failure in 2010 exchange server Exchange Server Administration 4
C UM Temporary authentication failure Exchange Server Administration 2
H OWA Forms Based Authentication Failing Exchange Server Administration 3
M Outlook Anywhere - Enable both NTLM and Basic Authentication Exchange Server Administration 8
R Code = "0x800CCC80; None of the authentication methods supported by this client are supported by you Using Outlook 3
I RBAC Authentication error - Remote EMC not able to access Exchange Organization Exchange Server Administration 13
