How to split screens in power point?
Jungleyes
Hello everyone!
I have a presentation coming up next week and I want to use power point 2010. The issue that I have is that, even though I know how to create a descent presentation in power point I would like to know if there is any possible way of having 2 screens, where in my laptop's screen will be displayed a text that will help me with my presentation and which I will be the only one that can read it, whereas on the projector's screen will be displayed the ACTUAL presentation in FULL SCREEN where the audience will be watching!
P.S. I know how to have the actual presentation on both screens (laptop's and projector's) or on my laptop's only or on projector's only! The case is that I want text in my laptop...presentation on projector!\
Thank you in advance!
G
G North
The feature your looking for is Presenter View. You can activate it via Setup Slide Show, on the SlideShow Tab. Check the option Show Presenter View in the bottom right corner.
As long as you have two monitor display support you'll be fine. You can use the option above the setting to control which monitor output shows the presentation. If your setup to show the presentation on both you screen and projector you may need to revert back to showing on just the laptop screen before this will work properly.
G North MMI
Jungleyes
G North MMI
Thank you I will try it...:)
C Split Screen Using Outlook 1
R View two Inboxfolders at the same time in split creen Using Outlook 1
K How to split large email when sending Using Outlook 1
H How to split up emails and faxes from a copier to the relay connector Exchange Server Administration 7
H 120GB single mailbox database, should it be split into several smaller databases? Exchange Server Administration 5
O Can I split existing Outlook 2007 email address book into two seperate sections Using Outlook 1
M 1. Split large videos or images into small chunks to send an email using Outlook 2007.__2. Maximum i Using Outlook 3
S Outlook 2007 - I just started, and have one huge Address Book imported from Outlook 2003 - how can I split up about 100+ Address book entries into sep Using Outlook 7
T Max. Size Outlook file / split into various accounts? Using Outlook 10
G Image scaling on high DPI screens Using Outlook 1
J MS Upgrade slowed down my Outlook view screens Using Outlook 1
G mal-function switching between 'mail' & 'calendar' screens Using Outlook 5
S Cannot maximize outlook screens and my emails are flipflopping. Using Outlook 1
K Following Several Power Cuts Can Only work in Safe Mode Using Outlook 0
L Adding a Win2k8 Domain User as a Local Admin or Power User in a Win7 machine. Using Outlook 2
S Outlook 14 lose contact with our exchange server 2010 after Windows 7 have been in power save mode. Using Outlook 2
S exchange power shell whether run on scheduler Exchange Server Administration 4
K Power shell Set full access rights based on users manager. Exchange Server Administration 3
M unable to send receive emails after power cut isp details checked and ok Using Outlook 2
C MS Outlook and Power Point. Lots of problems. Using Outlook 1
M Outlook 2007: How to enable my signature when starting an e-mail from MS Excel, Words and Power Point ? Using Outlook 2
H Outlook 2010 Locks Up after Power Down Using Outlook 2
N When trying to open 2007 Outlook/Vista, I get the error message below. Have no clue what caused this but I did have a power outage before this happen Using Outlook 1
M Cannot open Power point files received in Outlook Using Outlook 6
M The data file 'Personal Folders' was not closed properly message appeared after a power outage--cann Using Outlook 2
D Power down CAS servers, activesync stops working Exchange Server Administration 1
Forum Admin The Power of Word in Outlook - Outlook Team blog Outlook Wishlist 3
