Outlook 2007/2010 freezing when using Send To > Mail Recipient feature
Jonathan Boyko
Hey all,
I have this very weird issue on several machines using Outlook 2007/2010 + Exchange 2003. When in Windows Explorer I right-click a file (say, an xlsx file), choose Send To > Mail Recipient and, in the new email window, click the To button, the contact list opens but freezes for anywhere from several seconds to up to a minute. My machine is quite fast, thus the wait is fairly short, but on slower machines (E5400 + 4GB RAM) the wait can reach a minute in length. Sadly, the issue is quite frequent and I am able to reproduce it quite easily.
I recorded the issue, so you can find it here: http://www.youtube.com/watch?v=52HKZpaa3YE
Any help would be appreciated :)
"All parts should go together without forcing. You must remember that the parts you are reassembling were disassembled by you. Therefore, if you can't get them together again, there must be a reason. By all means, do not use a hammer." " IBM Manual, 1925
Sally Tang
What"s the version of your operating system?
You may need to set Outlook as your default email client:
1. Click Start.
2. For Vista/Windows 7, type " default programs" in the Search box. For Windows XP, go to Control Panel and find the option.
3. Click Default Programs under Programs in the search results.
4. Now click Set your default programs.
5. Highlight Microsoft Outlook on the left.
6. Click Set this program as default.
7. Click OK.
Sally Tang
Jonathan Boyko
OS is Windows 7 x64 (one version English another Hebrew).
This is totally insane, but at this moment your solution seems to improve things. Please allow this thread to stay open for another 24 hours for testing purposes.
Sally Tang
I am writing to see how everything is going with this issue. Is the problem resolved? If there is anything I can do for you, please feel free to let me know.
Sally Tang
Jonathan Boyko
Hi.
Finished testing today.
Strangely enough, this solution seems to improve the situation a bit - meaning the wait time before clicking the To field and being able to actually look through contacts is shorter - but does not solve it. I am currently trying to force the users to use the CTRL+K key combination, which seems to work just fine, with no delays.
I am starting to suspect my Exchange server - which seen better days.
If you happen to have any more suggestions, I'd love to hear them. If not - you are welcome to close this thread.
Sally Tang
That might also be related to the network issue in your network environment.
You may also check if it is quicker in the clean boot mode.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Sally Tang
Sally Tang
Sally Tang
P How to switch back from Outlook 2010 to Outlook 2007? Using Outlook 3
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
Z Copy Outlook 2007 "AutoComplete Contacts” to Outlook 2010 Using Outlook 7
M Messages Held in Outbox 2007 Outlook 2010 Using Outlook 1
V Outlook 2007/2010 - First time iCloud setup and config for heavy Outlook user Using Outlook 1
V Outlook 2007 vs Outlook 2010 on Windows 8 Using Outlook 18
G Outlook 2007 in Outlook 2010 asks for password Using Outlook 2
T Syncing OWA 2010 to Outlook 2007 Exchange Server Administration 15
M Searching Outllook 2010 shared contacts from Outlook 2007 Using Outlook 4
D Calendar Permissions Outlook 2003, 2007 and 2010 Exchange Server Administration 2
H Conflicts with other event in calendar ( outlook 2007 & 2010) Using Outlook 0
S Missing Color Categories Outlook 2007/2010 Using Outlook 2
J Move PST /changing default location in Outlook 2007 or 2010 64b on W7 64bit Using Outlook 2
I Send Secure Email Through Microsoft Outlook 2007 and 2010 (32 bit) Using Outlook 0
B Outlook 2007/2010 not downloading the OAB Exchange Server Administration 0
D Outlook 2007 & 2010 calendar permissions Using Outlook 2
S Calendar sharing problmes between Outlook 2007 & 2010 Exchange Server Administration 0
J Outlook 2007 and 2010 for multiple calendar users Using Outlook 1
D Inviting attendees Outlook 2010 and Outlook 2007 Using Outlook 5
D Outlook 2007 December 14 2010 (KB 2412171) Update Fix Using Outlook 0
S Outlook 2010 Journal does not record activities on Office 2007 files Using Outlook 1
D Outlook 2007 Slow Since Office 2010 Installed Using Outlook 1
P I have Outlook 2007 on a two year old computer running Vista. How do I copy my Outlook Contacts list and move them over to Outlook 2010 on a brand new Using Outlook 1
B Outlook 2007 New email notification works intermittently after adding Exchange 2010 Servers Exchange Server Administration 1
M Outlook 2010-Sync with Exchange server 2007 Using Outlook 2
W Unable to sync Outlook contacts and calendar since upgrading from Outlook 2007 to Outlook 2010 Using Outlook 1
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
M Outlook 2010 Connectivity with Exchange 2007 Using Outlook 5
J After Window update of 12/15/2010, outlook 2007 gives error (0x800CCC18) when accessing gmail using Using Outlook 6
T SharePoint 2007 MySites and Outlook 2010 Social Connector Using Outlook 1
K Outlook PST file created in 2010 can be used in 2007? Using Outlook 2
M Outlook 2010 Connectivity with exchange server 2007 Using Outlook 1
A cannot connect outlook 2007 clients to exchange 2010 Exchange Server Administration 3
S Re: Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
T Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
C Outlook 2010 Trial Is Up and Now 2007 Address Books Aren't Connecting to Contacts Using Outlook 24
G Share calendar between two Outlook 2010 OR 2007 without exchange where both users can make appointme Using Outlook 1
B Blank email list views on Outlook 2010 / 2007 with Exchange 2010 SP1 (on Citrix and Desktops) Using Outlook 7
T How Outlook 2007/2010 choose which Exchange Web Service to use? Using Outlook 1
G Subscribing to Shared Outlook Calendar 2007 / 2010 from invitation leads to user name and password request. Using Outlook 2
T Re: Outlook Anywhere in Outlook 2010 and Exchange 2007 Using Outlook 3
