Outlook 2010/Shared calendar showing as busy/no detail
jpresto
Hi, user has editor access to another user's calendar yet only free/busy information is showing.
The primary user's profile also has a second exchange account on it. Thought this account might be limiting things so gave it editor access as well. Still, only busy information is shown on calendar.
Anything else to check? Thanks in advance-
Sally Tang
Are those items set as private? If you select the Private check box on a Calendar item, Outlook does not grant Read permission to your Calendar folder to anyone whom you do not want to see private items.
Sally Tang
jpresto
No, none are private - this is across 4 user calendars.
It continues to work properly on user's old system, which is outlook 2007.
Sally Tang
Create a new Outlook profile for the user to test the issue again.
1. Exit Outlook.
2. Go to Start > Control Panel, click or double-click Mail.
3. Click Show Profiles. Choose Prompt for a profile to be used.
4. Click Add.
5. Type a name for the profile, and then click OK.
6. Highlight the profile, and choose Properties. Then Email Accounts.., add your email account in the profile.
7. Start Outlook, and choose this new profile.
If this problem does not occur in the new Outlook profile, the old Outlook is corrupted. We can delete that and use a new Outlook profile.
Sally Tang
Abdias Ruiz
What version of Exchange Server are you using and are you in Cached Exchange Mode or Online Mode? Please check the Permission settings on the shared calendar by opening the Shared Mailbox in Outlook, right-clicking on the Calendar folder and selecting Permissions. What are these set to?
For more information take a look at this article (note this also applies to Outlook 2010):
http://blogs.technet.com/b/outlooking/archive/2010/01/13/free-busy-and-calendar-permissions-in-outlook-2007-running-against-exchange-2007-or-later.aspx
Abdias Ruiz [MSFT]
S Outlook 2010 32-bit Shared folders Using Outlook 1
R How to copy outlook 2010 shared calendar appointment or meeting to personal calendar by vba? Outlook VBA and Custom Forms 1
W Outlook 2010 - Displaying Private Appointments In Shared Calendars Using Outlook 1
A Shared Calendar Outlook 2010 Using Outlook 4
K Outlook 2010, multiple shared mailboxes, reminder nightmare Using Outlook 4
C Permissions in Shared Task Folders (Outlook 2010) Using Outlook 1
C Viewing all Shared Tasks in Outlook 2010 Using Outlook 1
B Can't Remove Shared Contacts Folder in Outlook 2010 Using Outlook 2
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
M Searching Outllook 2010 shared contacts from Outlook 2007 Using Outlook 4
T Dates are not in bold from a shared calendar (Outlook 2010 ) Using Outlook 1
R Shared Inbox Outlook 2010 - one client cannot access Exchange Server Administration 1
G Subscribing to Shared Outlook Calendar 2007 / 2010 from invitation leads to user name and password request. Using Outlook 2
J Outlook 2010 Shared Calendar - Appointment Feature Using Outlook 2
I Outlook 2010: Appointments not visible in shared calendar if free/busy is set to Free. Using Outlook 2
M Shared Calenders very slow, Exchange 2007 with Outlook 2010 Using Outlook 2
N Shared Calendar in Public folder hangs when accessing from Outlook 2010 Exchange Server Administration 2
M Outlook 2010 - distribution list from shared contacts Using Outlook 2
L Outlook 2010 - Not seeing calendar items of shared users Using Outlook 1
C Re: Outlook 2010 - Shared Calendar sets all items as private. Using Outlook 3
R A shared mailbox is not visible in Owa but it is in Outlook 2010 cliënt? Exchange Server Administration 11
S Shared calendar in Outlook 2010 shows no appointments Using Outlook 7
S Is there a configuration or setting in Outlook (2007 or 2010) that allows users to rename "shared" c Using Outlook 3
C Cannot delete Outlook 2010 calendar items on shared calendars. Using Outlook 3
