How to Archive by Send/Receive Date, NOT Modified Date for exported/imported msgs?
shell_l_d
Is there a work-around for Outlook's archive feature to archive based on send/receive date NOT modified date please?
You'd think there'd at least be an option to choose what date type to use, but no.
Eg: I've managed to export 5yrs or so of Windows Mail messages to Outlook 2010 (as import in Outlook 2010 wasnt working as it should) & either way, it sets the modified date to today so I can't archive them into years.
Regards Shell Windows Vista
Sally Tang
We cannot change the methodology Outlook uses to archive messages. To work around this issue, manually archive the messages that were not archived by Outlook because their modified date is later than the date that you specified for archiving.
For details, you can refer to this KB article:
http://support.microsoft.com/kb/295657
Best Regards,
Sally Tang
shell_l_d
Ok taa, so there is no workaround, but just to manually drag & drop them all into yearly archive folders. As they all have today's date (5yrs worth of emails due to importing/exporting). There are about 20 diff folders with subfolders... wow, that's gonnna b a nightmare. You'd think Microsoft would've thought about the archiving more...Regards Shell Windows Vista
B Outlook 2016 Auto-archive creates new folder Using Outlook 4
D Archive by receive date not working Using Outlook 2
GregS Can't access archive file Using Outlook 5
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
S Moving Emails Between Archive Folders Using Outlook 1
M Multiple spurious empty folders appear in archive files Using Outlook 3
P Can't search Archive'd Tasks Using Outlook 0
C Merge two archive calendars Using Outlook 1
L Wishlist Archive mailbox - folder expansion Outlook Wishlist 2
B Relocating archive.pst file Using Outlook 6
R Enable Office 365 Exchange Online Archive New Slipstick.com Articles 0
R Enable Office 365 Exchange Online Archive Using Outlook 6
A Does Outlook import Gmail Archive? Using Outlook 1
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
K Different kind of issue related to creation of archive after one has been deleted Exchange Server Administration 1
skylark53 Archive a single Outlook 2013 folder tree Using Outlook 5
L Archive Shared Folders for all to Share Using Outlook 0
Z Manual archive of select folders Using Outlook 1
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
Jennifer Murphy Difference between export and archive? Using Outlook 10
D I can’t access my archive.pst Files Using Outlook 2
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
G archive attribute for email attachments Using Outlook 2
S Create rule to effect archive only Using Outlook 4
O Importing pst, archive pst and address not working Using Outlook 17
J Auto-archive with Exchange account Using Outlook 2
D Add data in archive.pst to outlook.pst Using Outlook 4
J Outlook 2007 Archive Using Outlook 1
R [outlook-users] Messages won't archive Using Outlook 5
T Move archive file to new hard drive and still be ablse to access it Using Outlook 1
M Max size reached for archive folders Using Outlook 1
R Exchange 2010 archive-prevent users moving items direct to archive Exchange Server Administration 1
A Outlook 2007 archive folders and files Using Outlook 10
H Opening .PST archive files in Outlook 2007 Using Outlook 10
A Is my archive too big? Using Outlook 1
S Outlook 2010: How do you enable Contacts' Activities to search archive folders Using Outlook 6
J Inbox not in archive Using Outlook 1
M Attachments in archive Using Outlook 3
D No longer able to Archive Outlook 2007 Using Outlook 1
W Nothing happens when using the Archive Using Outlook 3
R Outlook 7 auto-archive Using Outlook 1
L MISSING Archive in Outlook 2007 and WIN XP Prof SP3 Using Outlook 3
E Auto archive does not exist in my outlook 2007. Using Outlook 2
B Is personal archive email is cached in server memory? Exchange Server Administration 5
