Reply with custom form & selected data from message body
  • Thread starter Thread starter R3JlZ29yeUwuW0FJVEld
Hi everyone,
I receive a lot of plain text emails that contain data in a preset format
that I would like to auto reply with a custom form I have built. I would like
to know if I can locate and use certain values from the original message in
my reply (e.g. original msg contains as plain text First Name: John and
Coffee Type: Arabica. Can I locate John and Arabica in the original msg and
populate those values in my auto reply form -> Hi John, thanks for your
enquiry about our Arabica coffee range...)
It seems straight forward enough yet any help or pointers in the right
direction would be greatly appreciated.
TIA
Greg
You might find this code sample useful:
http://www.outlookcode.com/codedetail.aspx?id=89 It shows how to parse a
structured text block as your scenario describes.
Sue Mosher
"GregoryL.[AITI]" <GregoryL.[AITI]> wrote in
message news:2C54185E-4A80-4943-AC42-B9E7C1D7EE8B@microsoft.com...
> Hi everyone,
> like
> in
> and
> TIA
> Greg
Thanks Sue for the pointers and links, I'm almost there!
The example at
http://www.outlookcode.com/threads.aspx?forumid=2&messageid=696 is very close
to what I'm dealing with except the data value attached to each label is on
the line below it - see example...
<snip
Q. Email Address
A. John_Smith@domainname.com
Q. First Name
A. John
Q. Coffee Type
A. Arabica
<snip
I can successfully locate & return the Email Address label, how do I go the
next step and get the code to locate the label but return the line below it
for trimming and insertion into my reply email?
TIA -Greg
> > Sue Mosher
> > Hi everyone,
> > like
> > in
> > and
> > TIA
> > Greg
I'd use the same text parsing functions, Instr() and Mid(). Use Instr() to
search for the text "Email Address", then from that starting position,
search for the text "A:", etc. Use Mid() to clip the text.
Sue Mosher
"GregoryL.[AITI]" <GregoryLAITI> wrote in message
news:0E2CF2B3-3851-4092-B0FF-F5E5384F28D0@microsoft.com...
> The example at
> close
> on
> <snip
> Q. Email Address
> Q. First Name
> A. John
> Q. Coffee Type
> A. Arabica
> <snip
> the
> it
> TIA -Greg
> > > Hi everyone,
> > > format
> > > would
> > > like
> > > message
> > > in
> > > and
> >>> > TIA
> >> > Greg
P Reply / forward with a custom form. Outlook VBA and Custom Forms 1
T Custom Appointment Form Message Body Deleted upon reply. Outlook VBA and Custom Forms 3
L reply to message using a custom template Using Outlook 1
B Custom Properties or Reply Outlook VBA and Custom Forms 7
G Custom Forms: Attachment to be included in Reply Outlook VBA and Custom Forms 1
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
T In-line reply style in Outlook II Outlook VBA and Custom Forms 1
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
P Automatic Greeting "Hello Name," when Reply All is clicked Outlook VBA and Custom Forms 1
W Reply to email Using Outlook 4
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
ThinkToday Calculate reply time of outlook mail Using Outlook 1
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
E reply Using Outlook 0
evdbogaard Reply with only last message cited Using Outlook 1
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J VBA Run When Reply Outlook VBA and Custom Forms 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
