Some emails print very small
Bathgate Admin
I have a user in my environment that receives emails from 1 or 2 senders and they print very small.
These are trade emails that he has subscribed to that are produced in HTML format. It seems to only affect these two senders and all other HTML emails print fine such as those sent from users in-house.
The first time I encountered this I determined the root issue and explained to him that this is due to the coding of the HTML within the message and that it's the sender's fault. Now it's come up again and he's not accepting that it's the senders fault so I'm trying to make sure that I have my bases covered or if there is a work around before I approach him again. Oh..and it's my boss.
Anyone else encounter this? If so, How did you handle it?. I could force him to receive all emails as Plain Text but then he won't get "pretty" emails....
With regard to our environment, we are a Ctirix shop running Exchange 2003 with Outlook 2003 and Outlook runs in Online Mode.
Scott S., Bathgate, Wegener & Wolf P.C.
Bathgate Admin
Larry, I saw that one before I posted. It really seems t apply to the situation where all emails are printing small which is not what I am experiencing.
Nevertheless, that hot fix is covered by certain patches but those patches don't show up for my server os.
L
Larry
Hi Scott
What version of Internet Explorer are you running on the affected system? With Outlook 2003, HTML rendering is handled by Internet Explorer Components.
If you have access to them, do you see the same problem wiht later versions of Outlook?
Larry
Bathgate Admin
Larry,
All of our Citrix servers are running IE7. I would think that if IE7 was causing this then it would be all HTML formatted emails that would be printing small, not just a few. And I would think that all users would be affected as well, not just one.
I am not able to test later versions of Outlook at this time.
L
Larry
Hi Scott
Would it be possible to send me copy of a message that illustrates the problem?
If so, can you drag the message to the desktop (which will create a .msg file) and send it to me as an attachment to:
cts-larrymei at live.com
Larry
S Macro to print & move selected emails? Using Outlook 3
M button to send and print emails Using Outlook 26
W Cannot print Outlook 2007 emails Using Outlook 2
C Print all emails in a single folder with sent items Using Outlook 2
M trying to print emails but get Micorsoft Outlook contacting server for information Using Outlook 6
S how to print all emails sent and received via edge in 2010 Exchange Server Administration 13
R I am unable to print emails with attachments and also without attachments from sent & inbox of my ou Using Outlook 1
P How to batch print outlook emails and attachments? Using Outlook 3
J how do I print out the emails? Using Outlook 1
J Office 'closes' if print emails Using Outlook 2
M I CAN NOT PRINT EMAILS IN OUTLOOK 2003 Using Outlook 1
A how to print multiple emails from Outlook 2007 Using Outlook 13
J Moved many emails to Outlook external folder, need to delete on Gmail server Using Outlook 13
P Move emails between 2 mailboxes. Using Outlook 1
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
M Group of emails Using Outlook 1
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
P Flagging emails in conversations Using Outlook 2
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
F not receiving emails until i re-login Using Outlook 2
A Record opened emails for reopening later Outlook VBA and Custom Forms 16
R Deleting emails from storage folder Outlook VBA and Custom Forms 1
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
L Time format in Outlook calendar and emails Using Outlook 0
G Parsing All Emails Outlook VBA and Custom Forms 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
T Render Outlook emails in MS access as they appear in Outlook Outlook VBA and Custom Forms 2
O Delete duplicate emails - subscription notifications Using Outlook 5
