Controlling Outlook Setting not in general GPO Templates
1Dir
We have the Administrative Templates installed for both Outlook 03 & 07 and can manage options using GPO's, however is there a way we can control Incoming / Outgoing mail servers and advance settings using a GPO? We do not have the required version of 2007/2003 to use Outlook Customize Tool (OCT). The script we located to convert .reg to ADML template for GPO could work if we knew what part of the registry to export for the conversion. Is there a tool out there that can help with setting up default e-mail account settings i.e. Pop3/IMAP, SMTP etc....
We have hundreds of users and need the ability to conform these settings if possible.
Thanks much,
WH
Jahawk
Hi WH!
There's no GPO that would allow you set Account properties, but you can use a PRF to create or update\modify existing Outlook profiles.
Here is an article that gives an example of setting a POP3 Account's server settings in a PRF: http://support.microsoft.com/kb/259957
You can modify the sample PRF to do what you want, but I'd use the OCT to generate a PRF with the accounts set up like you need them. I don't understand your statement of not having the required version. You just need to go to the installation point and path to Setup.exe and add the /admin switch. Here's my path for Outlook 2007 (I have a flat of Office 2007 on my secondary drive): "E:\Office 2007 Enterprise\setup.exe" /admin
This is probably the article that will help you most: http://technet.microsoft.com/en-us/library/cc179062.aspx
You should be able to find everything you'll need off that page. :)
I hope that helps!
Jahawk MSFT
1
1Dir
Thank you kindly for your reply,
Our problem turned out to be a corrupted MSI loader file in Vista that kept us from installing/using OCT.
WH
W controlling margins in outlook emails with tables Using Outlook 1
D Outlook 2013 : controlling message size in Windows 8.1 Using Outlook 3
J Controlling/Changing owner of a Custom Contact item Using Outlook 0
J Outlook 2010 Outlook/Win7 Client logging Event ID 36887 Using Outlook 0
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
J Moved many emails to Outlook external folder, need to delete on Gmail server Using Outlook 13
P Scheduling a meeting in Outlook Outlook Wishlist 4
R Outlook 2019 Using Outlook 0
N Outlook Has Become Sluggish Using Outlook 14
HarvMan Outlook 365 Calendar Using Outlook 12
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Calendar Printing Assistant 2
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
L Outlook saved email templates Using Outlook 1
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
V Gmail in Outlook Using Outlook 0
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 3
T Pictures degrade each time an Outlook item is edited and re-saved Using Outlook 1
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
S Outlook not receiving mail Using Outlook 1
GregS Outlook 365 blocked by Google popup Using Outlook 2
T upgrade from outlook.com to Outlook Using Outlook 2
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
C Put Day of Year into Outlook Calendar Outlook VBA and Custom Forms 2
