cas array exchnage 2010 not working properly on vm
boris.ra
Hello ! I have 2 cas array servers installed on vmware , I also have database server in a dag . Users cant connect to outlook , when they try owa the can connect to each cas but not vertual name . I looked at notes from vm and created static arp , I still cant connect powershell test showed me that connection to mailbox server from cas works fine . I am using vm in multicast note
Sembee [MVP]
How have you created the virtual IP address address? NLB? There are known issues with Windows NLB, VMWARE and certain network switches.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
Steve Goodman
As Simon says this sounds like a VMware/Network switch issue. You're on the right track with the switch settings and using Multicast though. I would double check your switch settings and NLB config against the VMware KB 1006558; It may be worth running it past VMware but as they don't require any portgroup or virtual switch changes on the hosts they will probably bounce it back at Windows or the switch vendor
Steve
Steve Goodman
Steve Goodman
Pegoto,
He's using Multicast, not Unicast mode.
Steve
Steve Goodman
boris.ra
Guys ! Thanks so much for all POSTS , i did look at this articles and made manual adition to mac address tables on cisco access swicthes and arp entry on the router . and no luck , i guess vm vertual swicth is next to look at , unfort I am not that sawy with vmware , i used mostly xen before .
P DNS Round Robin on CAS Array Exchange Server Administration 5
B After rebooting one of the cas array servers blackbarry stops working Exchange Server Administration 1
S One CAS Array for mulitple site Exchange Server Administration 2
S CAS Array - NLB - Can't Ping VIP Exchange Server Administration 4
R accessing owa externally and having a cas array internally Exchange Server Administration 9
K CAS array SSL cert -RPC cas certificate warning Exchange Server Administration 3
S What to Use Instead a Hardware-based Load Balancer for an Exchange 2010 CAS Array Exchange Server Administration 21
R cas array owa is slow Exchange Server Administration 5
S Created CAS Array - Outlook certificate error Exchange Server Administration 2
S Exchange 2010 two datacenters two CAS array Exchange Server Administration 4
B Do we need to create a CAS Array for a single server site? Exchange Server Administration 3
M CAS Array Exchange Server Administration 6
R Installing SP1 on Hub/CAS servers in CAS Array Exchange Server Administration 9
R CAS array not working with Outlook Exchange Server Administration 15
B CAS Array article...? Exchange Server Administration 2
C Cas array question Exchange Server Administration 12
T Rename CAS array Exchange Server Administration 4
S CAS array legacy URL Exchange Server Administration 9
S CAS array in exchange 2003 and exchange 2010 coexsit environment Exchange Server Administration 4
S Looking for feedback on this CAS Array testing plan Exchange Server Administration 2
H CAS Array / OWA issues Exchange Server Administration 9
C CAS Array and Outlook Exchange Server Administration 3
C How to assign certificate(s) to an CAS array? Exchange Server Administration 1
C how should i assign an SSL certificate to a CAS array? Exchange Server Administration 2
Z Active SynC Issue in Exchange 2010 on CAS Array Exchange Server Administration 4
T CAS Array/RPCClientAccessServer and Outlook profile experiences Exchange Server Administration 8
W CAS Array and Autodiscover for Internal and external access Exchange Server Administration 25
C cas array and mapi Exchange Server Administration 1
A NLB, CAS array or OTHER issue? Exchange Server Administration 24
C Reboot a CAS array member causes Outlook 2010 clients to prompt for credentials. Using Outlook 5
L Cas Array failing when assigning using -rpcclientaccessserver Exchange Server Administration 3
C CAS Array : Outlook 2007 profile update Exchange Server Administration 2
R CAS Array Failover Issue Exchange Server Administration 17
K Outlook client on Exchange 2010 changes cas array name to instance-<guid> Using Outlook 21
A How to delete server members from cas array Exchange Server Administration 6
