not able to recieve Internal and external email on a 2010 mailbox... attempting exch 2003 transition
Mark Chris
Im going thru a exchange 2003/exchange2010 transition. I've had the server up for about 2 weeks and trying to get things to work. The install went great. Testing has been a headache. Initially, I could send and receive email (internal) from users on the exchange 2003 server to users on the exchange 2010 server. The issue I was trying to resolve was the users on exchange 2010 server could not send email (external), but could receive (external) email.
After some searching online, I decided to delete the SMTP connector on the exchange 2003 server and re-create. After that, my exchange 2010 users were able to send (internal/external) emails. However I have a new problem;
If I attempt to reply to the emails sent from my exchange 2010 users, both internal and external, I get a error(error details depend which mail service I am using), but I believe they are all the same.
This error is from an internal reply;
Your message did not reach some or all of the intended recipients.
Subject: RE: internal test
Sent: 10/25/2010 12:44 PM
The following recipient(s) cannot be reached:
exchtest on 10/25/2010 12:45 PM
A configuration error in the e-mail system caused the message to bounce between two servers or to be forwarded between two recipients. Contact your administrator.
<mail.domain.com #5.3.5>
this error is from a gmail account;
This is an automatically generated Delivery Status Notification.
Delivery to the following recipients failed.
exchtest@domain.com
Final-Recipient: rfc822;exchtest@domain.com
Action: failed
Status: 5.3.5
X-Display-Name: exchtest
I did some testing on both servers....
* I am able to telnet from the exchange 2003 to exchange 2010 and visa versa
* I ran the MailFlow troubleshooter and received the following results;
Area->Mail Acceptance->Server->'server name'->Mail submission failed: Error Message: The SMTP host was not specified.
I am at a loss here, wondering if someone could provide some insight.
Mark C
TWHarrington
Do you have multiple send connectors across your organization? What do your MX records look like? Are you just delivering inbound on one of the servers?
Numeric Code: 5.3.5
Possible Cause: A loop-back situation where the server is configured to loop back on itself was detected.
Troubleshooting: If you have multiple SMTP virtual servers that are configured on your Exchange computer, make sure that they are serving unique incoming ports and that the outgoing SMTP port configuration is valid to avoid looping between local virtual servers. Check the configuration of the server's connectors for loops. For example, make sure that no connectors exist that have the address space of the local organization, unless you share the domain and you do not select Use DNS to route to each address space on this connector. For more information, click the following article number to view the article in the Microsoft Knowledge Base:
321721 (http://support.microsoft.com/kb/321721/ ) Sharing SMTP address spaces in Exchange 2000 Server and Exchange Server 2003
Make sure that if there are multiple virtual servers, that none are set to All Unassigned.
Mark Chris
Numeric Code: 5.3.5
Troubleshooting: If you have multiple SMTP virtual servers that are configured on your Exchange computer, make sure that they are serving unique incoming ports and that the outgoing SMTP port configuration is valid to avoid looping between local virtual servers. Check the configuration of the server's connectors for loops. For example, make sure that no connectors exist that have the address space of the local organization, unless you share the domain and you do not select Use DNS to route to each address space on this connector . For more information, click the following article number to view the article in the Microsoft Knowledge Base:
Make sure that if there are multiple virtual servers, that none are set to All Unassigned .
It was the " all unassigned" in each virtual server in the two routing groups that was causing the problem. thanks for the assistance, I spent two days trying to figure this out before posting.
Mark C
S Unable to send emails through outlook, but able to recieve emails Using Outlook 2
N BCM suddenly crashed and not able to view specific business contact. Using Outlook 1
Fozzie Bear Wishlist To be able to add a local folder or network share location in foldern view Outlook Wishlist 1
L Outlook 2010- Be able to move default Mail folders (Outbox, Draft, etc) Outlook Wishlist 1
P Not able to receive meeting request Using Outlook 2
G Not able to send ANY emails due to a blocked list Using Outlook 2
D No longer able to Archive Outlook 2007 Using Outlook 1
N Not able to receive daily emails. Using Outlook 3
S I'm not able to copy and paste on outlook. Using Outlook 1
T Have to type in login to OWA twice before able to login Using Outlook 17
M Outlook Anywhere is not showing freebusy informayion and User not able to open shared calender while Using Outlook 1
R No problems for about three months and the, about two weeks ago I was no longer able to receive emails in Outlook. Using Outlook 4
D Not able to retrieve my emails or get to my contacts using outlook. Using Outlook 3
K Sending email in Outlook - being able to choose... Using Outlook 1
S Suddenly I am not able to send e-mail but can receive. We use Windows7 and Outlook has been working for about a year. Using Outlook 2
E 554 message not allowed [320] I am able to receive emails from these contacts but when i reply i get this error code. It is from contacts that i have Using Outlook 1
G Not able to accept meeting with outlook 2010 Using Outlook 0
J DAG problem - I´m not able to recover database Exchange Server Administration 9
G Not able to accept meeting with outlook 2010 Using Outlook 1
A error 2147504141 -I am not able to fix this error even after attepmting all IPv6 related sloution. Exchange Server Administration 3
D I am able to send emails on Outlook, but unable to retrieve emails trying to come in. Using Outlook 1
A Not able to search by last name in GAL Exchange Server Administration 3
D Not able to send mails through MS Outlook 2007 Using Outlook 3
S Not able to establish Outlook on Windows server, office email, yahoo account Using Outlook 1
D I would like to be able to Forward a Template to a specified email address on receiving an email in the Inbox. Using Outlook 1
H Not able to get messages forwarded from my road runner account. Using Outlook 2
B Switching Access from version 2010 to 2007 or 2003 causes Outlook to no longer be able to send or receive email. Using Outlook 2
S How do I set up more than 1 email account for Outlook 2007. Have recently purchased a laptop and want to be able to check all emails that come into t Using Outlook 2
M Not able to select my contacts list for my address book Using Outlook 7
M Need to copy old PST file from CD into Outlook so as to be able to open and view the old documents. Using Outlook 7
A SCOM 2007 R2 not able to see Exchange 2010 mailbox server Exchange Server Administration 4
S Not able to open webmail inbox. Using Outlook 2
S Me and my big mouth...I said to my customer a district nursing organization down here in New Zealand, that 2 ipaqs should be able to share the same Co Using Outlook 1
T Need to be able to check my microsoft outlook emails via my blackberry Using Outlook 1
O owa was not able to process this request Using Outlook 3
L I was able to password protect attachments in my earlier version of Outlook, but can't figure out ho Using Outlook 1
A not able to find Contacts when writing new email, even clicked the Searh Name button.__Try to set the address list or book, but nothing listed in the Using Outlook 1
L not able to access signatures to modify, add, or edit. Using Outlook 1
D I am not able to send emails from outlook 2003 Using Outlook 2
N Not able to select the details of a head office synced contact Exchange Server Administration 4
S Without Authentication able to send and receive email via POP3 - With Authentication not able to Send Exchange Server Administration 4
N I am not able to send emails in 2003 and emails are stuck in the outbox. Also must manually click b Using Outlook 1
C Office Home and Business 2010 working offline, not able to get back online. Was working online, not Using Outlook 1
S Inbox Repair Tool fixed problems but I am still not able to open Outlook Using Outlook 2
V NOT ABLE TO BOOK SHARED CALEDER (CONF ROOM) Exchange Server Administration 1
J Add a meeting / appointment to my Calendar without emailing the other person (like I was able to do Using Outlook 3
R i can not able to send mail through micrsoft outlook Using Outlook 3
